Question about Pioneer PRO-99 TV
Problem with pioneer elite pro-99
We have an older pioneer elite pro-99 and a few weeks ago it shut itself off when we were watching something. Ever since then when we try to turn it on, the power comes on for a split second ( no picture or sound though, just the green power button comes on) and then immediately shuts itself back off (the green power light turns to red). Any ideas or suggestions on how to fix this or what the problem might be? We have the same problem. Also, a click is heard inside when the power button is pressed and the standby/on light turns green to red.
This is a very common problem with these sets. I just had the same problem fixed on mine. Too bad Pioneer's service line is always busy and too bad they don't post the answer online. I couldn't believe it myself, the circuit board (approx. 12x13) needed to be resoldered. No parts required. The very reputable tech just turned the board over and started applying solder to about a hundred of the solder points. The set is working fine now.
Posted on May 07, 2010
  • Pioneer Master
  • 19,396 Answers
The click you hear is safety switch tuning tv off because it detects there is a problem.
Only simple thing you can try is keeping tv off for two hours, this will drain power off from TV resetting it, can fix some problem.
More likey your tv power supply is gone and need replacement, if it is not apower supply, then is some onboard component that has blown.
A call in for a technician will cost you $80, see if it is work.
Try unplugging first.
Posted on Aug 23, 2008
  • 3,037 Answers
It is most likely a problem with the power supply module and it will need to be replaced
    Master:
  • 763 Answers
Your tv's hardware might got the problem. this should fix with an expert technician that they have a tools for fixing this problem. if repairing will cost you alot then i suggest that you have to buy a new tv insted of repairing your old tv. hope that helps!
CHARCOIS
Posted on Aug 21, 2008
3 Suggested Answers
diodeic
  • 1622 Answers
SOURCE: have a Pioneer pro elite
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem....
Posted on Aug 09, 2011
tducksoup1
  • 7 Answers
SOURCE: Pioneer SD-532HD5 Projection Screen TV won't turn back on.
the problem with pioneer projection tvs is that when they made the boards they never used enough solder for the circuits and you get cracks in the runs. thats why heat and cold will effect it. I had the same problem and I took out the board and resoldered every track I could and it works good now but my remote wont work if anyone has any info or prints to this tv please post on here
Posted on Sep 15, 2010
Pioneer elite tv turns off from a pop sound and manual says-will
It is most likely the power supply. Do not try to fix this yourself. There are LETHAL voltages inside such a TV, which can persist for WEEKS after it has been turned off.
Jan 09, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer elite pro-99/pro-119 60inch projection 10years old. Picture stays on for 1&1/2 hours and then goes blank. have sound.Problem?
and does this sound comes for that one hour or not??
and do you hear any kind of clicking noise when the unit shuts down??
this seems to be like a thermal heating problem of some components.
Aug 12, 2008 | Televison & Video
TV keeps shutting off automatically
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
Jan 28, 2009 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Pioneer elite pro-530hd tv---no picture at all!
I have a 532nd 53 that shuts off and red stand by lite comes on in the back. If you wait awhile and unplug it and plug it back in it will come on again and then shut off after an hour or two
Jan 19, 2009 | Pioneer PRO-530HD 53" Rear Projection...
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
Pioneer Elite PRO-520HD POPS the SHUTS OFF
It could be a couple of things doing it. The lead on the CRT , The Flyback and or splitter are just a few of the things that come to mind. be careful as thats high vorage and a arching CRT or Flyback lead can be very dangerous . It is usually best to callm in a professional for those kind of repairs and diagnosis unless your a skilled technician , let a repair shop handle the problem and be safe.
Jun 12, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Pioneer Elite PRO-520HD wont stay on
It is most likely just solder connections on your power supply. If the only diag LED that lights is on the supply, then thats usually the case. You can unplug the set and remove the supply to fix it with a little soldering. You have to remove the metal board supporter from the bottom of the board and solder quite a few connections. Look for cracked connections on the power connectors to the rest of the set, and also connections on the main transformer. If you need soldering experience, get a kit at radio shack and build a little project to get some practice.
Apr 22, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Pioneer elite pro 100
My set is doing the same thing again. The last time I fixed this (4 years ago) it was a capacitor gone bad in the power supply for the 24v standby circuit. (C166)
The service manuals can be ordered directly from Pioneer Part Number ARP3014 for Pro-100 model.
Apr 10, 2008 | Pioneer PRO-100 TV
Pioneer elite 50" 1080 plasma pro-110FD We were watching the TV and suddenly it turn off with a loud boom sound, were trying to turn it on again but it only show a haft screen for a second then it...
You should be able to get in-home warranty service or an exchange at no cost. Don't void the warranty by trying to fix it yourself. Contact your dealer or manufacturer for service or a replacement.
Hope this helps :)
Apr 01, 2008 | Televison & Video
Pioneer Elite Pro-200
When it shuts itself down it is for the protection of the unit from further damage. It appears there may be something wrong with the power supply of unit. If you can get an inexpensive replacement board you just might want to go that route. On the other hand you have already gotten ten years out of it and you might want to move on.
Sep 01, 2017 | Televison & Video
Televison & Video Logo
497 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
