Question about Canon SmartBase MPC400 All-In-One InkJet Printer
Help me please
Hi !
I have a printer Smart Base MPC 190
when i want to change the cartridge as it is normally done, "wrong cartridge " message appear on the screen of the printer each time
how can i solve this problem
i'll be greatful to you
  • 48 Answers
Well..is it a direct replacement cartridge?
did you run a clean and alignment after installing the new one?
Also, more printer resources are here
Posted on Aug 21, 2008
How open in laser toner catridge make-xerox model-phaser 3100
Replace the toner: Always use the smart card provided with the new Print Cartridge when replacing the cartridge. The smart card contains the information necessary to reset the level of Toner. Replacing the cartridge without using the smart card may result in the consumable management system being inaccurate.
  1. Insert the smart card provided with the new Print Cartridge into the smart card reader. A "Change Toner?" message will be displayed.
  2. Press the [OK] button. An "Open Front Cover Replace Toner" message will be displayed.
  3. Push on the left and right side of the Front Cover and simultaneously lower the cover.
  4. Grasp the handle on the Print Cartridge, and then raise and remove the cartridge from the machine.
  5. Unpack the new cartridge, and then insert the cartridge into the machine.
  6. Close the Front Cover. A "Have You Changed the Toner?" message will be displayed.
  7. Press the [OK] button. A "Please Wait" message will be displayed while the machine reads the smart card, and then a "New Toner Remove Card" message will be displayed.
  8. Remove the smart card from the reader and dispose of the card as normal office waste.
    NOTE: If the smart card has been used with a previous installation of a Print Cartridge, a "Remove Card Already Used" message will be displayed. The smart card can only be used once. Make sure to use the card that came with the new cartridge.
Aug 30, 2010 | Office Equipment & Supplies
HP Photo smart c6180 All-in-one wrong cartridge
Hi The 363 cartridges that came with the printer MUST be used before any cartridges you buy in the shop are installed. The cartridges that come in the printer box are called "host cartridges" their ink is different and is required to install the printer for the first time. Once the installation ink is used, you are free to install & use any cartridges you would normally buy in the shops.
If the cartridge that came with the printer is not working, contact HP technical support and they should send you a free replacement.
Cheers.
Oct 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
Canon mpc 200 error message ''wrong cartridge'', won't print
if you have the old cartridge still check the connection to see if it is the same as you had and check to see if you have an original or compatible cartridge as some wont be recognised.if there is an electrical connection board in it see if you can change it onto the new one
Jul 31, 2009 | Office Equipment & Supplies
Unable to resolve 'cartridge has been changed' error message
turns out the wrong paper size was selected in the print setup. I set it to Postcard (4x6) and it began working perfectly again. Hooray.
Jun 01, 2009 | Canon SELPHY ES30 Thermal Photo Printer
Cover open message error
HI this will help you, I have located the link and this is going to give you all the info that you need.
Please do not forget to rate our chat session ok
www.fixyourownprinter.com/forums/printer/46998
Thank You
Jayson
Sep 21, 2008 | Lexmark X3470 All-In-One InkJet Printer
Mpc 190
drivers are here by model and operating system
www.canon.com
Jun 29, 2008 | Canon SmartBase MPC400 All-In-One InkJet...
Canon Smart base MPC 400 Printer
This printer needs these cartridges: -
1. (BCI-3eB) Black Ink Cartridge,
2. (BCI-3eC) Cyan Ink Cartridge
3. (BCI-3eM) Magenta Ink Cartridge
4. (BCI-3eY) Yellow Ink Cartridge
I think you need to clean your cartridge connectors with alchohol and retry.
Nov 21, 2007 | Canon SmartBase MPC400 All-In-One InkJet...
Canon SmartBase MPC400 All-In-One InkJet Printer Logo
107 people viewed this question
old marine
old marine
