Technics av control amp su-g88 classh+ - Sohowing Overload as soon as it turns on
Someone gave me thies receive (technics av control amp su-g88 classh+), when i connected the receiver, it says overload, Power off and On. I do it and it still occurs. Before i connected anything, since it was a gift, i opened it n checked the small fuses it had, they were good. Then when i conncted it showed me that, what can I do in reference to that.
  • Anonymous Oct 01, 2008
    it sais overload
  • 93 Answers
SOURCE: Technics SU-G91 OVERLOAD PROBLEM
OVERLOAD means that input signal level is too high. Can you be more specific? From which source you play music when OVERLOAD icon appears?
Posted on Oct 11, 2007
maklean
  • 1665 Answers
SOURCE: OVERLOAD MESSAGE
get a manual for ex-140 here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000031494.pdf
or try ( i didnt check it) for ex-400 "Unsorted Technics Service Manuals" at
http://www.user-service-manuals.com/technics-service-manuals.htm
Posted on Feb 28, 2008
freetek
  • 5568 Answers
SOURCE: Overload on Technics SA DA10
This is an old message so you may not be interested any more.
There are a couple of possibilities; the high power of this unit seems to fry speakers fairly often and although they mostly fail 'open,' they can overheat causing the voice coil to lose its insultation and cause a short instead.
This may also be caused by the failure of one or more output modules causing the power supply to limit and give you the overload indication.
If an output module has failed and the unit is not limiting current, it may destroy speakers too.
Some knowledge and a decent meter would reveal the nature of the failure pretty quickly but describing the steps necessary to troubleshoot this is a little beyond the scope of this forum.
Posted on Apr 23, 2008
Sparky2012
  • 102 Answers
SOURCE: My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Posted on Dec 04, 2009
Grubhead
  • 5342 Answers
SOURCE: on switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Posted on Mar 09, 2010
My technics av control stereo receiver sa-g76 keeps shutting off(overload). can you please advise on how to avoid this situation?
Is there anything on top of the av receiver? Try and run the reciever so that it has enough cooling. B) Allthough overload, there is a possibillity it is causes by speakercables who are shortcircuiting once in a while. Usually somewhere at the back of the reciever or speakers.
Apr 24, 2014 | Audio Players & Recorders
Amp keep's sating overload
Have you tried disconnecting all the speakers and inputs and turn it on?
If it still shuts off you have an internal problem, if it stays on, connect one item at a time until it shuts off and that is the problem.
Jan 13, 2013 | Panasonic Technics Sa-gx690 Av Control...
Does the SU-G88 AMP carry a remote control and can you advise where I can buy one from? Is the amp for sale and how much?
Search engines would reveal those answers faster than waiting for one of us to do it for you.
It DOES use a remote.
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=SU-G88&uuid=A13093555179681
http://cgi.ebay.com/Technics-EUR646496-SADX930-SAAX730-SUG88-SAAX7-Remote-/260761453202
Fixya experts provide free advice that would otherwise not be available online or easy to locate, not sales or a proxy search engine service.
Jun 29, 2011 | Technics SUV500 2-Channel Amplifier
Technics SU-G88. When volume is wide open get small amnount of sound, as sugested I have already replaced the op ic IC602 and this did not help. Is it possible that both audio power modules bolted to the...
problem with electronics is there are so many possibilities! before changing the power amp i suggest u check all the paths from pre-amp to power amp. bad resistors cud be it, faulty capacitor cud be draining power to ground. insufficient power supply to final amp cud also be it. so before making any rash changing pls check all components including the power amp module.
Mar 14, 2010 | Technics Audio Players & Recorders
I have a technics su-g88 a/v control amp, when i turned it on today, everything lights up and works but no matter what device i choose to listen to i get no sound. worked fine 2 days ago, also the fan in...
some technics models use hybrid o/p i.cs and when they go faulty shutdown the o/p to both channels. it is also possible that the fan not working can also cause this fault
Feb 07, 2010 | Technics SUV500 2-Channel Amplifier
Dec 04, 2009 | Technics SA-AX530 Receiver
I have a technics amplifier SU G75
I have a technics too, and faced the same problem. The solution is very simple just ensure the +ve and -ve wires are connected correctly for each speaker to the amp. Eg. red wire to the red knob and black wire to the black on both ends. sometimes this arises because the wires are of just one color however there will be some marking on the wire to indicate which is +ve and -ve. This took care of the overload problem.
Jun 18, 2009 | Technics SA-AX530 Receiver
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
Oct 10, 2007 | Technics SA-AX540 Receiver
474 people viewed this question
 Grubhead
Grubhead
