Question about Lexmark T644dtn Printer
Reset Lexmark T644
How can I reestablish, the maintenance counter of the lexmark T644, I replaced the fuser, but the message of the maintenance continues.
I will appreciate your help.
thank you.
  • Anonymous Mar 18, 2014
    only black pages
1. Turn off the printer. 2. Press and hold (check) and .(right arrow). 3. Turn on the printer. 4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. 5. Select Reset Maintenance Count from the Configuration menu. 6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Posted on Jan 26, 2009
  • 48 Answers
Hmmm..that's a firmware update..you might find instructions at www.lexmark.com go through knowledge base..
Also, more printer resources are here
Posted on Aug 21, 2008
How to reset Lexmark t650 fuser unit?
Fuser's don't have a 'reset'.....they just get hot and melt the Toner onto the paper.
I think you mean "how to reset the maintenamce counter".
Go to this page and watch this video for replacing the Fuser Kit on your model printer.
Lexmark T650 T652 T654 Fuser Maintenance Kit Replacement and How to...
Oct 13, 2014 | Computers & Internet
Lexmark t644 is showing "920.06
920 error is cold lamp on fuser replace fuser will clear problem
Sep 25, 2011 | Lexmark T644 Laser Printer
When you turn on the printer, the code 80, code appears to want to reset the wrong network
code 80 is maintanance message askinfg for the fuser charge and transfer roller to be changed. to reset counter hold tick and right arrow will go into config menu you can then reset counter. but if you do not change parts it will start to jam due to fuser at end of life
Aug 15, 2011 | Lexmark T644 Laser Printer
Lexmark T644 920.16 Service Fuser Error What do I need to do to repair this problem?
Lexmark gives the following list of all fuser errors and recommends what action you should take (Lexmark Knowledge Base). that the fuser unit failed to reach the standby temperature.
  • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
  • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
  • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
  • 920 Fuser Error message indicates that the fuser unit in the printer is below the proper temperature for printing.
  • You may need to replace the fuser: watch this video:
    http://www.youtube.com/watch?v=RjQkR4x9fqw
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
    Jan 24, 2011 | Lexmark T644 Laser Printer
    HOW TO RESET LEXMARK X642E FUSER KIT COUNTER
    Hit the menu button or the Key Button
    Go into the configuration menu
    Touch the arrow that says "Reset Maintenance Counter"
    Select the Yes button. as you can not manually change the page count number.
    It will reset the counter for you.
    Oct 15, 2010 | Lexmark X642e MFP Laser Printer
    How reset the printer maintenance counter for the lexmark t642
    Here's an article in the Lexmark website on 80 Scheduled Maintenance" Message Appearing on a Lexmark T640, T642, T644, or an X64xe Series Printer. Included in this article are instructions on Resetting the maintenance counter to zero. Just click on this link: http://bit.ly/9pzU7R. Read thoroughly and follow the instructions carefully. Scroll down for the instructions on resetting the maintenance counter.
    NOTE: RESETTING THE MAINTENANCE COUNTER SHOULD ONLY BE DONE ONLY AFTER REPLACING A NEW MAINTENANCE KIT.
    Jun 29, 2010 | Lexmark T642 Laser Printer
    Lexmark T642
    There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
    Apr 03, 2009 | Lexmark T642 Laser Printer
    Setting print count on Lexmark T644
    I'm assuming you mean the maintaince counters... Turn off the printer. Press and hold the check and right arrow buttons on the front of the printer
    Turn on the printer. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. Select Reset Maintenance Count from the Configuration menu. The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
    Dec 17, 2008 | Lexmark T644dtn Printer
    9,158 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
