Question about RCA Televison & Video
I have a Magnavox TV and I tried all the Program Codes for my TV and the remote control still does not turn off or on my TV. The light went out on several of the codes, just as the directions say. What do I do to correct this problem? Thank-you.
  • 927 Answers
Good Day, kilcullenphn;
I have a car and need a an engine where should I go?
I think my auto is a foreign car. THE point is ; need Model Number.
Thanks, big IRISH.
Posted on Aug 21, 2008
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
RCA Universal Remote Control- Target Programming ...
Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
I need to program a remote for a philips magnavox tv and need codes
Hello
Setup codes to check with Magnavox TV to Magnavox remote control are:
002 009 109
118 209 309 402 408
502 508 510 807 914 917
OK.
Nov 06, 2011 | Philips Magnavox Learning Universal Remote
I NEED TO PROGRAM A MAGNAVOX TV WITH A PHILLIPS UNIVERSAL REMOTE CONTROLL
Find codes and methods here.
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
Oct 08, 2010 | Universal Remote Control Universal IR...
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 17, 2010 | Universal Remote Control DIRECTV Universal...
I have a GE universal television remote, and have lost the code. I need to know how to program my MAGNAVOX TV.
Here are the codes,004,008,009,062,068,069,074,075,076,077,089,133,141,163,165,226,288,456,...Turn TV on, press and hold CODE SEARCH until the light come on, press TV ,the light will remain on, enter one of the three digit codes,the light will go off, if not, try another code until it does, press POWER, the TV should turn off....hope this was helpful....
Apr 25, 2010 | Universal Remote Control GE174Universal...
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 08, 2010 | Televison & Video
I have an rca universal remote and a magnavox tv. cant find the instructions on how to program
try this, press and hold the tv button on your remote about 3 sec. light should stay on, then enter code, if it's a good entry light should shut off, then try to turn tv off. make sure your tv is on before trying this. If tv does shut off then you're done if not try other codes magnavox codes0062 0004 0009 0183 1133 0226 0288 0456 0008 0068 0075 0141
Feb 20, 2009 | RCA Universal Remote Control
Televison & Video Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
