Zojirushi NH-VBC18 10-Cup Rice Cooker Logo
Posted on Jun 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i find the inner cooking pan replacement for NH-VBC 18
Angel Joseph Jr.
Level 2:
  • Zojirushi Expert 685 Answers
  • Posted on Jul 03, 2011
Angel Joseph Jr.
Zojirushi Expert
Level 2:
Answers
685
Questions
0
Helped
219709
Points
932
Hi there.
Visit http://www.zijorushi.com for parts inquiry.
Regards.
So can we get a 10 QT Rival roaster Handle?
Amazon is the best place
Rival Roaster Parts - Amazon.com
https://www.amazon.com > Rival-Roaster-Parts > k=Riv...
Results 1 - 48 of 171 - 18 Quart Electric Roaster Oven, Roaster Oven, Turkey Roaster ... Heavy Duty Electric Roaster Liners Full Size Set of 10 (Fits 16 to 22 Quart, 34 x 18 Inch) ... Universal Pot Lid Replacement Knobs Pan Lid Holding Handles.
Rival Replacement Parts - Amazon.com
https://www.amazon.com > Rival-Replacement-Parts > k...
Results 1 - 48 of 845 - Oval Glass Lid for Rival 7-Quart And 6 1/2 Quart Black ... Universal Pot Lid Replacement Knobs Pan Lid Holding Handles (1 Pack) ... Sunbeam, Oster, Rival Microwave Oven Cooking Plate 10-1/2-inch ... rival roaster parts.
Sep 23, 2019 • Cooking
How do you cook a hickory smoked ham shank portion that is fully cooked already?
I place ham in a large roasting pan or large rectangular pan using a rack under the ham. Set oven to 325 and cook 15-18 minutes per pound. I make a glaze. I glaze half way through cooking time and then a second time 15 minutes prior to removing from oven.
Apr 16, 2017 • Grilling
Can i cook two boxes of cake mix together in one ten inch square tin, to make a large cake?
According to Duncan Hines - no. One box of mix will cook properly in a 10x2 pan assuming it is the same height as your regular cake pans. Here is some conversion info that I copied from one of their mix boxes: 1 box of mix yields 5 1/2 cups of batter. 5 1/2 cups can be cooked in a 10x2 pan and should take about 40 - 50 minutes. You can make 2 cakes and stack them for a big cake but all that batter in one pan probably won't cook right. Two boxes of mix need a 15 x 2 round pan or an 11 x 15 x 2 rectangle pan. I hope that helps!
I need to buy the inner cooking pan for my zojirushi rice cooker model NH VBC 18 Where? and How much? Thanks
Hi there.
Try visiting http://www.zojirushi.com, you will be able to find the nearest authorized parts dealer.
Regards.
1helpful
Need bolt torqe specs , rods, mains, oil pump & oil pan for 6.0 vortec engine thanks
Connecting Rods: First pass 15 lb ft. If you have an early first design final pass 60 degrees. Second design 75 degrees.
Main Crank Bolts: Inner bolts first pass 15 lb ft. A final pass additional 80 degrees. Tighten the outer bolts/studs 15 lb ft. Final pass 53 degrees.
Tighten the side cap bolts to 18 lb ft. Tighten the bolt on ones side of the bearing and then tighten the bolt on the opposite side of the same bearing cap.
Oil Pump Bolts: 18 lb ft.
Oil Pump Screen Nut: 18 lb ft
Oil Pump Screen Bolt: 106 lb in
Oil Level Indicator Tube Bolt: 18 lb ft
Oil Level Sensor: 115 lb in
Oil Pan Drain Plug: 18 lb ft
Oil Pan Bolt: 18 lb ft
Oil Pan (to front cover): 18 lb ft
Oil Pan (to rear cover): 106 lb in
Oil Pan Skid Plate Bolt: 15 lb ft
If you need more specs contact: [email protected]
8helpful
Do you put water in the botom pan
No water between the roaster and the cooking pan!
If using with the buffet server insert, put a couple inches in tn the cooking pan below the buffet pans.
Here is the manual for additional help:
http://www.rivalproducts.com/manuals/MANUALS/RO188BR_43_81844057.PDF
1helpful
Do you have to put water in the first pan to cook a turkey?
Absolutely not. This is an oven, not a steam table, and water in the main roaster actually interferes with heat transfer. Water in the roaster cooking pan (the inside pan) actually steams the turkey, not a yummy solution.
3answers
Sticking of cooked rice inside pan
Buy a rice cooker with non-stick inner pot.
Top Zojirushi Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
