Question about Panasonic CT-32SL14 32" TV
Can't get dvd player to hookup correctly
How do i hook up a dvd player???? I don't think I have all the right cords for the hook up. I have a Panasonic CT32G6 32" TV and a JVC XV-NP10S dvd player. I have one cord with the white, yellow and red ends. What am I missing? Pictures?
I searched the internet for the user guide and used it to solve the problem. I had the proper equipment, it was a matter of a switch being on the right setting.
Posted on Aug 21, 2008
SOURCE:
How do I hook up this DVD player to my 60 inch Westinghouse model #VR-6090Z ?
If your DVD player has HDMI, use it. If not, you'll need to buy a cord for it. Look on the back of the TV and the back of the DVD player. There should be colored connectors on each one. On the TV, it will be an input. On the DVD player, it'll be an output. There will be either 3 connectors or 5 connectors on the TV and DVD player. You'll need a cord with either 3 connectors on each end (red, white, yellow), or one with 5 (red, white, blue, green, red). Once you figure out which cord you'll need, buy it from any store that sells TVs and hook it up. The link below has pictures
Video Connectors Tutorial Hardware Secrets
Feb 02, 2015 | Westinghouse Televison & Video
How do I hook up dvd player with a cablebox?
Most TVs have several input selections on the back so you don't have to go thru the cable box. Look thru your TV owners guide for the best choice
Feb 03, 2012 | Cyberhome DVR 1600 DVD Recorder
I bought a dvd player i also i have direct tv not sure if cords are hooked up correctly
Read ur DVD player owner manual?The DVD player have a HDMI hub.Used a HDMI cable to hook up the DVD player are the easiest way.The Satalite Direct Tv is working,fine on ur tv right?So don't worry about it.
Sep 30, 2010 | Maxent MX-27X1 27 in. HD-Ready LCD...
Hook this dvd player to an hdtv
You are confused regarding how to connect your DVD player to your Samsung TV. There is no such thing as "5 composit hookups". Your DVD player most likely has right audio (commonly red), left audio (commonly white), and video (commonly yellow) outputs which should be connected to corresponding inputs on the rear of your TV.
Dec 15, 2017 | GE 5803P Multi-disc DVD Player
Ps3 hookup to panasonic plasma viera
Actually if you do have a ps2 you don`t really need a Dvd upconverter because Ps3 is a full Dvd player +blu Ray Hi Definition.I suggest to take the dvd out and just use the ps3 as a Dvd player
Good Luck
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
DVD and PS2 in Black and White
HDTV:
DVD:
Jan 20, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
Panasonic CT-32SL14 32" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
