I have a Mitsubishi VS60-609. It was given to me, and untill I pluged it in had no idea what to expect? It has a picture and sound, but looks like it is in 3D! I thought it just needed a good convergence, but in the advanced convergence screen it loks like an hourglass. The grid is bowed at the top and bottom of the screen. What could this be, and how can I fix it? Any help would be greatly appreciated! Thank-you, John in Ohio.
  • 927 Answers
Good Day, John in Ohio;
Even though I'm from MI I will try to help you. Your TV uses a convergence IC > STK393-110 HIC > Part number > 267P140020. This model only uses one IC. The cost of IC is $27.20 from MIT but could get at local supplier cheaper.
Good Luck, big IRISH.
Posted on Aug 21, 2008
I get sound but no picture then the tv shuts off after 5min. It is a Mitsubishi wd-73837
Popping noises are not a good sign; I suspect the sound came from the catastrophic death of an electrolytic capacitor or worse, the death a a power semiconductor.
Open the lower cabinet and using a good light, look for a smaller, separate board with fairly large parts on it; some cylindrical in shape, others block-like that may have copper wire showing.
If, as common, this board is plugged with connectors into other parts of the system, you may be able to swap the failed board out for a replacement bought from a Mitsubishi service center.Expect to pay $100-$150 US if the set is no longer under warranty.
Nov 23, 2011 | Mitsubishi WD-73837 73 in. HDTV
Green light but no picture or sound.
First thing you wanna try is a manual video reset.
It's probably a good idea to hook up the regular av cables as well.
While the PS3 is off (red led)
Hold down the power button until you hear the second beep, quickly release.
Let me know what happens.
Jun 17, 2009 | Sony PlayStation® 3 (60 GB) Console
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
WS 55315 Tv won't turn on-
Thanks for your help can you send photos so I can see what to look for
Dec 01, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
Visit the site linked here for more details. Repair of many popular brand devices are given. http://electronicshelponline.blogspot.com/
Mar 23, 2017 | Televison & Video
I have no idea so if you can help thanks
The board on the left will have a series of small aluminum heatsinks with black ICs attached to them one of them will be the vertical output IC with about 7 pins on it. try resoldering those ICs and you should get the picture back as the vertical ICs will make the tubes cut off. The vertical IC should be marked on the board but solder all the ICs mounted to heat sinks on that board to be safe.
May 13, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Trouble!!
sounds like a loose video cable. Check your connections
Mar 03, 2008 | Mitsubishi VS-60601 60" Rear Projection...
IS THIS TV PLAYING OUT
Color separation is called convergence mis-alignment......that
problem can be repaired...............Blurry,darker when cold may
be a bit of difficulty..............Have a skilled tech give it a look.....T.
Nov 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
