Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher had to replace the discharge hose on my dishwasher. After I put everything back together we went out for dinner while it ran thru a cycle. We returend to find the bottom of the unit full of water. Can you tell me why and how to solve this problem? Thank you for your time. Jeff
  • 725 Answers
Did you route the hose with a loop in it ...? is the water dirty or fresh? I can help
Posted on Sep 14, 2008
Dishwasher repair. Problem: water in bottom of machine, not draining/ cannot select any mode other than 'Auto'/ usually does not start. What happens when I try to run it: Switch on. On switch lights
I had a similar issue. I took off the drain hose, ran hot water thru it and removed the hose going into the garbage disposal there was some built
build up on the inside, cleanness it good put through houses back together and everything was fine. Hope this
Dec 23, 2014 | Dishwashers
WE JUST BOUGHT A NEW DISHWASHER DU1345XTVB HOOKED EVERYTHING UP CORRECTLY AND RAN A QUICK CYCLE THRU IT AND WHEN IT WAS DONE THERE WAS STILL WATER IN THE BOTTOM. THIS WAS TO REPLACE THE OLD DISHWASHER SO...
Make sure the garbage disposal is working, if it is not then it will not allow
the dishwasher to drain. Also make sure there is not blockage in the intake port on
the disposal where the hose connects itself. If you installed a new disposal, there
is a knockout that must be struck out inside the connection port.
If you have an "air gap" installed (next to the faucet which looks like
a small cup upside down, it may be gunked up, remove and clean, or replace it)
If the hose came inside the dishwasher did you install it on the proper port on the
dishwasher pump, many have two and one is blocked off. (it is unlikely but depending
on the amount of water and the type of subflooring under the machine, it could have
pumped out unnoticed and drained through a wiring hole).
Hope this is helpful
Mar 26, 2011 | Whirlpool Dishwashers
Zanussi dishwasher DA6142s discharge hose
With most dishwashers that i have pulled apart it is at the bottom of the dishwaher. You should be able to remove the bottom plate (under dishwasher) and take the clap of and put a new one on.
If you have any questions plese dont hesitate to ask
Dec 02, 2008 | Zanussi Dishwashers
Whirlpool QP II dishwasher - Not draining
I had the same problem... I jiggled the washing machine.. the discharge hose seemed to be clogged.
Oct 21, 2008 | Whirlpool 24 in. DU1100XTPS Built-in...
My dishwasher won't drain
It is possible that it ran thru the entire cycle but was unable to drain teh waste water ( usually the result of a clogged filter screen in the bottom of your dishwasher).. I suggest you either hand bail the water out and look for the drain filter screen or check where the drain hose is hooked up under your sink and possibly into the side of a garbage disposal..That could be clogged up too... Hope that helps...
Aug 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher will not drain
We took it all the way apart and cleaned it really well in the bottom of the dishwasher. Then we put it back together. Then we removed the hose from the disposal and suctioned it with the wet/dry vac to remove any clogs, then put that back together.
Ran dishwasher with Tang in both powder cups to clean it, and it's running fine now.
Apr 20, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
49 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
