Question about Intel Motherboard
Desktop Which monitor is better LCD or CRT and Why?
  • 197 Answers
If i have to pick i would pick the lcd because it take up less space and there easy to clean very easy to hook up the tower and if your running xp or vista it will atomaticly detect it the price of them isnt bad better then crts and the lcd s last longer then crts do. they also come with built in speakers so you dont have to buy any external speakers.
thanks
hope this help
Posted on Aug 21, 2008
My monitor give white lines]
The only way of repair is to replace. CRT monitors are obsolete. Your are better off buying a new, LCD, one.
Jun 28, 2014 | Dell E551c (Dark Gray) 15 in.CRT...
No picture on screen
Try connecting the CRT to a different (desktop or laptop) computer, to confirm that the CRT is still working.
Try connecting a different CRT (or LCD) monitor to your computer, to confirm that your computer is sending video-output.
If possible, try a different "data" cable between the computer and the CRT.
Jul 20, 2010 | HP Compaq FS7600 17" CRT Monitor
What are the possible disadvantages of computer monitors?
a CRT monitor, those big glass ones , that are as deep as they are wide, those ones i personally think give better picture and seem better when watching movies, because there is less tearing of the picture (when it lags behind the sound)
both LCD and CRT monitors are going to use more power when attached to a laptop than the laptops built in screen.
usually a computer monitor can be a higher resolution (more desktop real estate) than a laptop screen.
beyond that, there arent many downsides to having a monitor attached to your PC. - i guess another disadvantage of a computer monitor is that they don't float in water, they are heavy to carry , and don't fit in your pocket, however, that all also applies to the desktop computer itself.
Jul 15, 2010 | Computers & Internet
I used CRT monitor now iconect hcl 710 Lsa model lcd monitor no signal disply. an other cpu accept his monitor working good what problem ? My cpu core 2 duo intel prosser 2 gb ram 2ghz
Possibly, the CRT monitor was set to a frequency which is too high for the LCD monitor.
Try booting in Safe Mode (press F8 at boot), then set the video for a lower resolution.
Reboot with the new, lower, resolution.
In Control Panel choose Hardware, then Scan for New Hardware and get the LCD monitor recognized.
Then, from the Desktop properties, you will be able to see all resolutions supported by the monitor.
Nov 03, 2009 | Honeywell Computers & Internet
Monitor not working
If this is LCD monitor, The power supply of you LCD need to be repair.Ask technician to fixed this power. LCD monitor need to epen and replace defective parts
Jul 26, 2009 | Computers & Internet
Laptop comes on but monitor remains black
IT could be one of two things. First make sure that you have the laptop set to display on the LCD. Most laptops will have a Function key labeled by Fn then you will need to look at the function keys at the top F1-F12 and find the one that either says CRT/LCD or has a picture of a screen or monitor. Then, after you have found that key, you will need to press and hold the Fn key and tap the appropriate function key, this will alternate between the LCD (laptop) and CRT (monitor). If you have trouble finding the correct key combination for switching displays should be listed in the manual.
If that doesn't correct it, then I would try locating a desktop CRT and connecting it to the monitor connection on the rear of the laptop and again pressing the keys to switch between CRT/LCD. If it shows on the CRT then I would say that the LCD on the laptop is bad.
Thanks
Aug 28, 2008 | Computers & Internet
Crt 4:3 to a 16:9
If your CRT Monitor has a DVI input you can certainly get HDMI to DVI adaptors (Maplin etc) but if the monitor is Analogue as I suspect you will need to find a Digital to Analogue converter. The problem here is that HDMI is copy protected and any analogue outputs must be disabled when HDMI is selected to prevent coping. I am assuming this also applies to your PS3 !!!!
I do agree with you about picture quality. I have a Samsung 21" CRT monitor which has a pixel size of 0.2 and is far superior to even the best LCD.
Apr 24, 2008 | Televison & Video
Hooking up a second ACER monitor as an extended desktop
I have 2 acer AL2016W's and have the same problem. The earlier ones with the VGA only are the problem from what I can see, they just don't play nicely with the video card for some reason.
First, on your main monitor, click "Show displays in menu bar" on your monitor control panel. This will let you set the resolution for each monitor from the main one, click on the little monitor icon on the top right screen to do this.
If that doesn't work try this:
Connect one acer as the main monitor and one crappy vga crt monitor as the second.
Set mirrored desktop in the system preferences so that the crappy CRT is displaying the exact same resolution as the acer. (1680x1050 59.9Hz)
Disable mirrored desktop. You should now have an acer and a crappy CRT both running 1680x1050 in extended desktop mode.
Shut down, reconnect the acer in place of the crappy CRT.
This should "trick" your video card into having the right resolution, otherwise you'll just get the stupid "input not supported" screen, with no ability to auto configure or use any of the built in controls.
Nov 20, 2007 | Acer AL2016W 20" LCD Monitor
Intel Motherboard Logo
22 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
