Question about Motorola Mobility V710
HI i'm naili
What's a new flex cable?
  • 1,800 Answers
Hi nailie this is me if u want some infos contact me here i will fix everything u want okay this is my email
jalal_sordo@otmail.com
be quick
by the way give me fix ya rate so i will be satisfied for a while he he ^ ^
Posted on Aug 25, 2008
  • Jalal Sordo
    Jalal Sordo Aug 25, 2008
    wow nailie that was so fast and furious okay okay
    i will never answer ur questions
    by the way u r the one who began this by giving me ur Phone Number!!
    remeber??
My laptop screen is blinking
Hi
you laptop screen flex cable may have got loose or getting ruined.
so re-plug the flex cable connections firmly. if problem still persist then replace it with new flex cable.
Thanks.
Aug 12, 2012 | HP Computers & Internet
The cable that connects motherboard with the board that holds the keyboard and the camera is cut how can i repair it
the flex cable is the part that has been disconnected from the motherboard.
you can easily install a new flex cable to the motherboard yourself provided you have the appropriate tools to do so.
a flex cable from ebay will cost you $30-$50, if you have common electronics knowledge i would say that replacing the flex cable to motherboard would be an easy DIY task.
Aug 15, 2009 | Nokia 3230
Retrieving data, broken screen
hi
The Phone needs a new Keypad flex and most likely a left hinge pin. When the phone is open, the cable runs through the left side of the hinge. It is very common for the hinge pin to become chipped and put a small cut in the Flex Cable.
You can get the parts on ebay. search for motorola v3 keypad flex, and motorola v3 hinge, or knuckle.
thankyou.
May 04, 2009 | Cell Phones
LG Shine CU720 Flex cable replacement
well take apart the lcd part and the keypad part and strat connecting the flex cable.
use this trick:
use ur digital camera to take shots for every step u performed so u not getiing lost after taking the phone one part.
aslo while repalcing the ld put the new on it place!!!
Jan 30, 2009 | LG Shine CU720 Cellular Phone
Flex cable change
If you buy one without camera then yes you do have to take it off the old one and put it on the new one. My best thing to do with this one is to just buy a flex with camera already on the new cable. The camera has very small parts and it is very delicate if you are not sure how to take them and move them to the new one. It is not that much more to just buy with camera and you don't have to worry about it working if it is a fully functional flex cable new. I hope this helps if you need more help let me know and I will do my best to walk you through. If you want to try to take the camera off and put it on the new one I can walk you through but I cannot guarenteed on your end it will work. Like I said very fragile and delicate. Good luck!!
Aug 23, 2008 | Sony Ericsson W300 Cellular Phone
Hi i'm naili
okay nialie.
when u drpped ur CP the flex cable that connect the screen to the keypad has damaged or maybe moved a lil bit from it original place
dissemble the phone and try to connect it again and tell me okay nailie.
Aug 21, 2008 | Motorola Mobility RAZR V3
Razr v3 flex cable connected but screen is still black
You can buy a new phone.....but I had the same exact problem with my motorola v3 phone. Every now and then both screens would work for a while and then turn completely black or sometimes white. Most of the time black. The keypads would light, I could make and receive phone calls, but I couldn't see anything on either screen. I moved all my contacts to the sim card and I got a new phone thru an upgrade with my company. But I was still determined to get the V3 to work again! I brought the phone to a few cell phone repairs shops and I was told that the connectors from the flex cable inside the phone sometimes get loose. Make sure they are tightly plugged in. If that doesn't help then the flex cable needs to be replaced. Some of these repair shops wanted up to $65.00 to replace the flex cable! I could replace the phone for much less than $65.00! So I decided to go to ebay and type in Motorola V3 Flex cable......hundreds of places came up that sell this flex cable. I found a place in my area and ordered one. It cost me $5.00 and I got it within 2 days! I looked online on how to install the flex cable and everything from how to disassemble the phone to installing the new flex cable and reassembling the phone was right there! I followed the instructions and I installed the new flex cable and the phone is as good as new!!! Both screens are working and I didn't loose any pictures or contacts from the phone!
All it cost me was $5.00 and about an hour of time! It even came with free shipping! Go to google and type in Motorola v3 black screen and look thru the solutions. Some of them will explain how to disassembe the phone and replace the flex cable with detailed pictures! You can buy the torque screw drivers at Home Depot or on ebay! Good Luck!
Jul 15, 2008 | Motorola Mobility RAZR V3
Help
you may have a faulty phone ...needs to be returned...the flex cable in the screen is damaged or loose.does the screen come on at all?
if it does that means your screen flex cable is faulty and if it doesn't your main flex cable is loose maybe from a fall or water damage.This needs to be handled by a qualified service tech. to get to the main flex cable the screen cover would have to be removed via the four screws located under the 4 rubber stubs on the main inner screen.You need to have a t6 otr a t4 screw driver to remove the cover.the main flex cable pops right off but the ear piece flex cable is a little more difficult.thanks !
sam !
May 12, 2008 | Motorola Mobility RAZR V3
No sound through earpiece/white screen
you can send too sony ericsson it in if you are the origanal buyer and they will fix it for free but it also has to be under a year old
or if you are on a plan you can get a new phone every two years its not free tho it is very cheap you have to be with at&t to do that tho (cingular)
Jan 28, 2008 | Sony Ericsson W300 Cellular Phone
Motorola Mobility V710 Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
