Convergence issue with the red color tube - Televison & Video
  • daviditch Aug 21, 2008
    BIG IRISH.....
    Thank you so much for the information. it was very helpful.
    Sincerely,
    ~daviditch~
  • 927 Answers
Good Day, daviditch;
Yes sir, it sounds like you have a convergence problem. You should contact an Authorized Service Center and get an estimate before repairs begin. It will cost about $300.00 to $650.00 depending where you are located and the Model, Brand of the TV.
Good Luck, big IRISH.
Posted on Aug 21, 2008
  • MICHAEL MULLINS Aug 22, 2008
    You are welcome, I was glad to help.
    big IRISH.
SOURCE:
I have a Sony KDP-57WS550 TV that has a convergence problem. Based on the symptoms, I'm not sure whether to indict the convergence ICs. In the convergence mode, I can move the red (and blue) crosses,...
With your TV in setup Use a small magnet to "move" the non converged Red, Blue, or, Green color lines "crosses" (each CRT will need to be adjusted in turn) by moving the magnet close to the offending Red, Blue or,Green color CRT yoke or, tube while observing the movement of the CRT color line "cross" in a mirror ( try several places near the tube and, several strengths of magnets:) a refrigerator sheet magnet works well (you can cut these with a scissors to make a better fit or, apply less magnetic "pull." by making them smaller (you may need more than one magnet per tube to fix each CRT's convergence) When you have each CRT tube's convergence right, apply some clear silicone adhesive to the magnet and, permanently affix the magnet to the now "fixed" CRT tube exactly where you placed the magnet to obtain the best convergence on the CRT.
(Do not adjust the "Green" CRT unless you must, as it is used as the color line to adjust other lines to)
Jun 30, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
Red is ghosting to the right. i replaced the convergence tubes about 6 months ago. went with the expensive ones "not the cheapy's" used heat sync putty stuff and everything. the problem is...
Yes,the tv problems it is the same,it is the tv convergence problems again,now it just color it is shaded in shadows pictures,instead of wavies mis colors R,G,B mis alignments.Yes.The tv convergence board it is the problems,must be repair again.
Apr 27, 2011 | Sony KP-57WS500 57" Rear Projection...
I have a toshiba tv model tp50g90 I have replaced the convergence chips stk392-110 convergence was corrected but I have a problem yet red not managed to focus on the user menu in the option of...
Thats the way it works. You have to adjust the other colors to the red. You adjust the red from the back of the set using the convergence magnets on the tubes. Then you adjust the other colors to match the red. It's much easier if you have the plastic screen from Toshiba used to align this set.
Feb 20, 2011 | Toshiba TP50G90 50" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Have a rear projection tv 55pp9352. Has green halos around objects on the screen. Checked convergence and all red and blue line up except that on the outside edges the convergence crosses are somewhat...
yes, you need remplace the liquid in the picture tube green and blue, and need remplace 2 parties stk-392-120 and resistences 6.8 ohms at 1/2 watts
Jan 05, 2010 | Televison & Video
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Wavy Red lines
hi there,
if you are familiar with electronics you can do this :adjust voltage at hight voltage block it has screen and focus written on it and comes from flyback transformer,but be careful cause it can be to dangerous if you touch something else,ah,ah adjust only the one that says screen and has a R on top,that means red,ok,thanks.
Jun 19, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence
Color tubes are OK. Do not adjust. The issue at hand is called
convergence alignment.The repair involves-------
1)Pull chassis
2)Replace convergence IC's
3)Recheck alignment
work should be done by a skilled technician........T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
Open Questions:
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
