Windows will not load.gets error...file.partmgr.sys missing
Could u give the detail info about your system?
Posted on Aug 21, 2008
Hello to everyone, I have been reading forums for
This is a typical sign of a defective hard drive.Your hard drive might or might not be repairable, depending on the degree of damage.
I would recommend that you use a live CD (such as this one: to boot up your computer & run a hard disk diagnostic tool like HDD Regenerator. It might take several hours (sometimes days) to fix the damage. If this did not help, then you will have to replace the hard drive.
Jul 22, 2011 | Acer Aspire 4730-4516 Notebook
When i plug the hard drive my computer wont detect. only the bios can detect.and i cant reformat it it says.a problem has been detected. i boot it from cd and after the windows setup it displays" a...
This usually happens when u fit any hardware to the system....The information which u gave seems its "Blue Screen of Death" or "BSOD" ........ if u have seen this screen only after u plugged in yr HDD, try with other HDD. Perhaps there might be an error with the HDD which u have plugged in.
Jun 13, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
A problem has been detected. i boot it from cd and after the windows setup it displays" a problem has been detected and windows has been shutdown to prevent damage to your computer the problem seems to be...
If you're running Windows XP (Any version) or Vista open the link provided below for instructions on how to repair you're master boot sector other wise known as fixmbr;
Read everything.
Jun 03, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
I am having trouble running setup on my desktop
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
Aug 28, 2009 | Computers & Internet
Hi There,
I just experienced the same problem you did concerning the partmgr.sys blue screen error. I am installing Windows XP Pro SP2 on a pretty old Dell Latitude LS (upgrading it from Win 2000). The XP installation disk gives me the option to format in NTFS, FAT, and both formats in a "quick" mode. I usually do not recommend using the quick mode, however, after trying both NTFS and FAT and receiving the blue screen, I decided to try NTFS (quick). That has allowed me to actually get further into the installation, so you may want to try that.
May 27, 2009 | Microsoft Windows XP Professional
That error is your partition manager, Go to this site and download Partition Magic
This normally happens when you have got more that 1 partition on your hdd....
Try Partition Magic, and see if resolves your problem
Good luck
As you boot up the computer, keep on pressing the F8 key, you will be able to get into the Windows Startup Menu and be able to select Safe menu.
You most likely have a problem with a bad block in the page swap file area.
You may still not get Windows to open, and basically your need to format the hard disk and this will lock out the bad blocks and then you can install Windows again.
This also indicated your hard disk is wearing out and more than likely you will get more bad blocks and this will cause further problems such as computer locking up to data file corruption and or loss files etc.
You have an old laptop (it must have come out of the ark), it is not fixing, unless you can get another hard drive very cheaply, put your money towards a new one.
Jan 02, 2009 | IBM ThinkPad 600E 2645 Notebook
Can you boot into safe mode? You can access safe mode by pressing F8 before the windows logo appears on start up.If you can access safe mode without any errors,then the problem is likely to be caused by a driver.Let me know what happens.
Aug 21, 2008 | Computers & Internet
Cannot reboot windows xp home.file error...partmgr.sys missing
You need to do a windows repair.You will need your XP installation disc.Refer to this link for more details on doing a repair.
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
