Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Removing control panel
I'd like to remove control panel to replace membrane. Two touchpad keys -- the + and - keys, used to adjust temperature or set timers -- are not functioning, even after toggling breaker a few times.
Dacor told me only authorized repairmen are taught how to remove the panel!
  • 1 more comment
  • bobbomo Aug 21, 2008
    I already know (from Dacorservice.com) that the part number for the ERD30 membrane is Part 755601. WWhat do not know is how to take off the control panel so that I can get to the membrane. I took off the 4 screws under the panel, but it still doesn't budge.
    "after all the suggestion ..."
    What suggestions are you taking about?
    No, that's the standard "Use and Care Manual" for owners. Nothing about removing control panel. Thanks for trying.
    Problem Solver:
Posted on Jan 03, 2009
  • Dov Barak
    Dov Barak Jan 05, 2009
    after you remove the control module (4 screws), you have to remove 6 screws for the membrane,
    but
    you have to release to front panel in order to tilt it so that you can reach the screws
  • 6,487 Answers
You can check this link for this concern , just copy and paste the link..
http://www.dacor.com/WorkArea/downloadasset.aspx?id=10859
Hope that helps...........
Posted on Aug 21, 2008
    Master:
  • 763 Answers
After all the suggestion and still didnt worked then it should deliver to your nearest technician to fix your problem. hope that helps!
CHARCOIS
    Scholar:
  • 163 Answers
G1022
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jun 13, 2013 | Miele Dishwashers
Tip
Repairing an (F2 E0 or F2 E1 error code) Failed Whirlpool Builtin Oven Keypad...
A replacement touchpad is now available from Ledgestone Technologies to replace various membrane keypad switches that are not available from the OEM.
These are in stock and can be shipped today from fixyourboard.
Find the full list of applicable models here:
Introducing the Ledgestone Technologies Touchpad
Step 1. Remove Original Plastic Bezel
BE SURE TO REMOVE POWER TO OVEN FIRST!
You are going to re-use the original plastic bezel. Remove the panel from your oven that contains the keypad and control board. Uplug the keypad from the control board. Remove the control board from the panel (4 screws).
Step 2. Remove Original Touchpad Membrane
With a heat gun, lightly heat the original keypad from the back of the panel. This will soften the adhesive. Gently but firmly push the old keypad off the bezel by pushing from the back of the panel on the keypad window. Carefully remove the original keypad membrane element. Most of the original adhesive should pull off with the keypad. Rub off any remaining adhesive.
Step 3. Install New Ledgestone Touchpad
Remove adhesive backing paper from the Ledgestone Technologies KP1308A1 Replacement Touchpad Membrane. Align and adhere new touchpad to recess in plastic bezel. Below are examples of black on black and gray on white. Gray also looks good on bisque or almond.
Step 4. Re-install Bezel on Oven
Re-attach control board to bezel, plug-in new keypad. Re-attach bezel to oven frame. Done!
Applicable Models
RBD276PDB10 RBD276PDB11 RBD276PDB12 RBD276PDB7 RBD276PDB8 RBD276PDB9 RBD276PDQ10 RBD276PDQ11 RBD276PDQ12 RBD276PDQ7 RBD276PDQ8 RBD276PDQ9 RBD306PDB10 RBD306PDB11 RBD306PDB12 RBD306PDB13 RBD306PDB14 RBD306PDB15 RBD306PDB7 RBD306PDB8 RBD306PDB9 RBD306PDQ10 RBD306PDQ11 RBD306PDQ12 RBD306PDQ13 RBD306PDQ14 RBD306PDQ15 RBD306PDQ7 RBD306PDQ8 RBD306PDQ9 RBD306PDT11 RBD306PDT12 RBD306PDT13 RBD306PDT14 RBD306PDT15 RBD306PDZ10 RBD306PDZ7 RBD306PDZ8 RBD306PDZ9
Original Whirlpool Touchpad Part Numbers
4451969 4451970 4451975 4451976 4451977 8300431 8300432 8300437 8300438 8300439 8300640
on Aug 17, 2015 | Ovens
Want to raise the water temp
Stand alone water heaters have temperature controls in different locations.
Most residential electric water heaters operate on 240 volts. Please, shut off power first whenever you need open or remove panels for adjustments or servicing.
"Traditional" electric water heaters have them behind removable panels - like the top and bottom gray panel on the water heaters on the right side of the photo. Both panels have adjustable controls behind them and both should be adjusted to the same setting.
Some newer electric water heaters use electronic controls. These may be accessible without removing panels and even have digital displays. Others have controls that are located on the top of the heater - behind a panel. Electronically controlled water heaters may or may not need to be powered on when making adjustments. Check your manual if in doubt.
Gas (propane & natural gas) type water heaters have the temperature control on the gas valve. There are often two controls on the valve, one for the pilot (off, light and on positions) and a second for temperature adjustment.
A tankless water heater built into your home's furnace is controlled by an "aquastat". An aquastat is a fancy term for a thermostat to control water temperature. A typical aquastat is mounted directly on or very near the furnace and looks like this:
Inside, are several temperature settings. Here's a photo of the interior of the Honeywell aquastat:
The Hi dial should never be set to a value lower than the Lo dial. "Safe" settings are Hi = 180, Lo = 160 and Diferential (above "Lo") = 10. You'll need to tweak these up a bit to make water hotter. You should read more about settings for these aquastats here. Skip down to the section titled "What Settings To Use on a Heating Boiler Aquastat Combination Control"
I hope this helps & good luck!
Nov 22, 2012 | General Electric GE SmartWater Household...
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
The touchpad is locked
On some models there is a button at the top of the touchpad in the middle that toggles the touchpad on or off.
On other models you simply tap twice in the upper left hand portion of the touchpad to toggle it on or off.
And then there are some models that you use keystrokes to toggle the touchpad. Normally you would Press and Hold the ALT or FN function key near the bottom left portion of the keyboard then hit the key that toggles the touchpad. The key that toggles the touchpad will have the icon of a finger pointing at a square which represents the touchpad.
Below is what I found in your user manual on the touchpad. It looks like your touchpad is controlled by software and there is no button or keystrokes that control the toggling.
Customizing the Touch Pad and Track Stick You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel, click Printers and Other Hardware, and then click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
Below is a link to your manual
http://www.support.dell.com/support/edocs/systems/wsM70/en/ug/keyboard.htm#wp1052329
May 09, 2012 | Dell Precision M70 Notebook
Cursor does not move when running my finger over the touch pad. Thank You Bill
1. Adjust the touchpad sensitivity from the control panel. Perhaps lessening the sensitivity will solve the problem. In Windows OS go to your control panel, and select hardware and sound. Then click "mouse," and when the new window pops up select the settings tab. From there you can adjust the sensitivity. If your mouse came with its own software you may be able to adjust the settings from the system panel. Hover your mouse over the icons near the system clock, and look for an icon that is titled touchpad, or mouse. You can click this icon and adjust settings.
2. Clean the touchpad with rubbing alcohol in case there is a grease buildup on the touchpad. This is the most common cause for touchpad failure.
3. Remove the touchpad drivers from device manager and reinstall. Sometimes there can be driver errors that are preventing the touchpad from working. Device manager can be accessed via control panel in Windows systems.
4. Replace the touchpad if none of these steps work. Prices can range from $15 to $50 plus labor rates. It is best to let a computer professional change this since major disassembly is required to remove and replace the touchpad, and many fragile components will be exposed during this process.
Hope this help. Goodluck!
Mar 28, 2011 | Computers & Internet
I've had the acer one for 2 weeks. While using it today, the single and double click functions of the touchpad stopped working. The touchpad still moves the arrow around the screen and the left and right...
Hello cskpuels,
It sounds like the touchpad is working ok but probably needs some setting(s) adjusted. The touchpad settings can be accessed through the windows control panel. But before going to the control panel it's useful to review the touchpad basics for single and double clicking. They are as follows:
•Tap once on the main touchpad for single click.
•Tap twice for double click.
•The lighter the touch, the better the response.
•Tapping harder will not increase the touchpad's responsiveness.
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
*The Enter key may be used on the keyboard in place of touchpad clicking*
In the Control Panel, do the following:
•Select Mouse [Enter] (Brings up the touchpad properties sheet)
•Look at the Buttons tab in the touchpad properties sheet.
•Adjust the settings and test the touchpad until you get the response you desire.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
Whirlpool Oven Control Panel Thermal Fuse
If the display is totally out it is likely the thermal fuse this is located where the wire connectors plug into the board it looks like a small resistor in a platic shrinkwrap type sleeve. test it with a continuity meter.
Oct 25, 2008 | Ovens
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
514 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
