I've charged my Targus wireless mouse (PAKP003U) and plugged in the USB adapter thing, making sure the light is on. The mouse is on also, but it is still not working.
  • 25 Answers
Your windows computer must install the drivers for the wireless adapter for your mouse when you plugged it in. Given that the light is on the adapter I'm assuming it works.
There should be a small button on the mouse and the adapter somewhere. Press the button with a paperclip or something small enough to get to it and the light should start flashing. Now press the button on the mouse. Both lights should be on solid.
This connects both the adapter and mouse on the same wireless channel to work together.
Good Luck!
Posted on Aug 21, 2008
SOURCE:
Targus Model PAWM002 optical mouse will not work. When I plug the stick in the red light comes on and I have replaced the batteries in the mouse. Turned the switch on the underside of the mouse on and the...
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
(if applicable)
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps dont forget to vote
Feb 28, 2011 | Targus Wireless Mini Optical Mouse
Recently installed a Targus keypad. You have to
defective, I think.
return to the store for another one.
Jul 09, 2010 | Targus Wireless Keypad/Mouse PAKP003U
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: www.targus.com Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Feb 08, 2010 | Targus Wireless Optical Notebook Mouse...
Cant click on anything..
If the red sensor that glows (on the bottom) is not on or flashing, you need new batteries. In that case, pry open the battery cover and replace. If it is on and it's not working. Try one of these things.
  1. Click the reset button on both, the mouse and the usb adapter.
  2. Making sure the device is installed properly, if not you might need a new mouse.
Hope this helped. Message me if it does or doesn't and I'll try to help more. (I have a Targus wireless mouse for my Toshiba laptop)
Good luck.
Jan 03, 2010 | Logitech Cordless Mouse
Describe your Targus Wireless Keypad &
there is no need of softwere for both. im now using logitech brand. But we need to set progrram in control pannel. we should use battery in mouse and key bord. To contact usb senser. thanks ( nepal)
Jul 11, 2009 | Targus Wireless Keypad/Mouse PAKP003U
I have the Targus wireless mouse amw10us. It just
Mine did the same thing, so I took it apart. The flip hinge in the receiver wore through the wire running between the plug & the little board inside. I'm shopping for a new mouse.
Mar 11, 2009 | Targus PAWM001U Mouse
Model PAKP003 Won't work
You will need to reset the id code on the the receiver as well as the device. Here is the direct link to the manual with the detailed instructions (please, cut and paste to your browser):
http://www.targus.com/us/Downloads/PAKP003_UG.pdf
The Targus link to the product itself:
http://www.targus.com/us/drivers_manuals.asp?SKU=PAKP003U
Good luck
Feb 03, 2009 | Targus PAWM001U Mouse
MICROSOFT WIRELESS MOUSE FOR LAPTOP DOESN'T WORK
There's also a connect button on the USB connector. Plug the connector in and press the connect button underneath until the light flashes. Release the button and click the connect button on the mouse until the USB light is steady.
May 16, 2008 | Targus PAKP003U Keyboard
Wireless mouse and keypad
DO ONE THING GO TO ADD REMOVE PROGRAM AND THEN GO TO ADD HARDWARE AND THEN CLICK HAVE DISK IT WILL RECOGNIZE YOU CD DRIVE THEN I WILL ASK FOR INSTALLATION THEN YOU GO THROUGH
Feb 15, 2008 | Targus PAKP003U Keyboard
My wireless mouse and keypad won't work...why
Try loading driver software and plugin the wireless Keypad & mouse
Sep 03, 2007 | Targus PAKP003U Keyboard
Open Questions:
Computers & Internet Logo
79 people viewed this question
Ekse
Alun Cox
