Hi jenkinsbebeg,
There's a possibilty that you will get an unstable connection due to unsecured Linksys setup. Poeple around you can pick up your network easily and could eat up your bandwith. So it is highly recommended to set up a security on your router. There are several options on how to set up or configure your router. You can use the setup wizard or by opening your web browser.
Here are some steps on how to set up your router using your web browser:
1. Open your web browser ( Internet Explorer, Mozilla ).
2. Now enter the the following URL:
http://192.168.1.1
3. Enter your Username and Password.
common username and password for linksys:
--> username blank, password "admin"
--> username "admin", password blank
--> username "admin", password "admin"
4. You need to connect to the internet then click "internet setup".
5. From the drop down menu select DHCP for cable modems, and for DSL modems please select "PPPOE".
6. Now set the SSID (Service Set Identifier) to identify your network name. You could also change the password from here.
7. At this point you can encrypt your wireless connection using the WEP ( Wireless Encryption Protocol ) or WPA. If you will be using the WEP just go under " wireless security" option, then enter your preferred password (passphrase) then click on "generate".
From here you should now be able to connect to your router using your preferred password.
Hope it helps.
Thank you for using FixYa.
