Got home, turned TV on and vertical white lines. Changed TV Input and colors changed. Took out Monitor In and still had lines. Turned on DVD and still had lines. Even unplugged the TV, still had lines. Do you think the TV is toast or can be repaired?
The lines only move when you hit the TV Input. They move from Right side of screen to the middle of screen and change from white to yellow. The lines only move when you hit the TV Input. They move from Right side of screen to the middle of screen and change from white to yellow.
Hi techs, I have the same problem with this hitachi with the white lines on the right and yellow lines move to the center of the screen. if anyone has a solution or fix . I would appreciate it. thanksHi techs, I have the same problem with this hitachi with the white lines on the right and yellow lines move to the center of the screen. if anyone has a solution or fix . I would appreciate it. thanks
You can't post conmments that contain an email address.
Do the lines move at all, or are they static? Someone else had a similar problem, and a fix that might work for you was posted at: http://www.fixya.com/support/t293678-plasmaa_tv_not_going
If the lines are moving at all, even with changing the input select, then that's probably a good sign. You may want to try buying an inexpensive ground isolator to help with possible power interference or grounding issues. It couldn't hurt to try this easy fix first before investing any money in sending it out for repair. I hope this solves your problem!
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
