Problem for Receivers
Generic problem for all Receivers
I have some doubts about
I have some doubts about my VRCD400-SDU autoestereo installation, could you please send me an example of how should be connected the stereo wires?
Already I have completed the connection but I dont sure how or where connect the dashboard ligth dimmer switch and amplifier remote/power antenna wires...
CURRENT PROBLEM: If I turn on the TAIL.L ILLUMINATION switch on my car the 10A fussible for this option inmediately is burned and the unit(VRCD400-SDU) change the status to turn off...I dont sure what is wrong...
please help
thanks
R. Oroz
robelectro@hotmail.com
Comments:
Aug 21, 2008
- Thank you tech48 for your quickly response....I will get a car harness for my audio system in order to perform all connections properly.
But I still having some doubts, previosly stereo installation I checked each wire of the current car harness using a digital multimeter to make correctly all connections. I can identify speakers, 12 V and ignition wires but rest of wires (3 wires) are phisically connected to GND, by this reason I use ramdonly one of them as GND stereo reference, rest two wires are dis-connected; however, still having two wires (antenna and dashboard light wires) that I cannon connect because I am not sure how perform that.
ThanksAug 22, 2008
- Thanks a lot tech48, now is very clear for myself !!!
Best Solution
posted on Aug 21, 2008
Rank: Guru
Rating: 94%, 528 votes
Here is a link to the owners manual for your radio, it should have all the information you need in it for wiring it properly.
http://www.roadmasterusa.com/forums/index.php?act=attach&type=post&id=46
Comments:
Aug 21, 2008
- The illumination wire is usually orange and it should be connected to whatever wire in your factory car harness is used for that same purpose. You need to know which wire on your car factory harness is for that purpose. If your car does not have one, leave it dis-connected. The remote/power antenna wire is for turning on an external amplifier or for turning on a power antenna. If you are not using it for that reason, leave it dis-connected as well.
Since it is blowing a fuse when you connect the illumination wire, you must have it connected to the wrong wire. I do not know what wire in your car would be used for this reason, you never said what type of car you have.
You should be using a universal wiring harness for connecting to the factory harness in your car, then it is a matter of matching colors. You can get them at car stereo installation retailers, they connect to the factory harness and then you connect that to the radio's harness.
If you have problems still, you should consider having the radio installed by a professional. You may have an issue that would be difficult to resolve in a forum since your car is not available to check by anybody but you.
Aug 21, 2008
- Did your cars factory radio have an illumination adjustment on it? If not, you do not need to connect the illumination wire to anything. You will just have full illumination on your new stereo with no way to adjust it (that's how I like it). The illumination wire is not a required connection. Many radio's are like this when you put in an aftermarket radio and the original factory radio did not have an illumination adjustment. Sometimes the illumination wire for the factory radio is the wrong type for the aftermarket radio and it can not be used. It is OK to leave it dis-connected, just put some tape on the end so it doesn't short out against anything in the dash.
Do you have a power antenna (one that raises and lowers when the radio turns on), or an external amplifier for a sub woofer or extra speakers? If not, you don't need to connect the blue wire to anything as well. You do not want to connect those wires to any of the 3 wires you identified as ground. The blue wire for the remote/antenna wire will blow a fuse if connected to ground, it is a turn on for external reasons as mentioned (amp or power antenna) and it puts out 12 volts when the radio is turned on.
You have done a good job of identifying the wires correctly, don't let the fact that you have 3 ground wires make you think that something is wrong. Not all car stereos will be able to use every wire that the harness has. If you are certain that those 3 wires are all connected to ground, then you have your choice of what wire to use for your new stereo to use as ground. I would pick the wire that is the thickest. The ground wire should be about as thick as the yellow wire for proper installation.
I think that if your radio is working, you get sound frm all the speakers and it turns on and off properly and keeps the memory when it is turned off, then you have done everything you need to do and have done it properly. So, good job!!!
Popular Solutions for Receivers
Questions and Unsolved Problems for Receivers
Is there a wsay that I can convert my Bose wave radio/cd player from 220v to 110v, without an...
(More)
Is there a wsay that I can convert my Bose wave radio/cd player from 220v to 110v, without an external transformer ,having moved from the UK to Canada?
My onkyo receiver is set up to play audio from DVD/VCR player, CD/Cassette/phone players, and Blue...
(More)
My onkyo receiver is set up to play audio from DVD/VCR player, CD/Cassette/phone players, and Blue ray player as well as the DISH receiver. When first set up, everything worked. When I tried to get a DVD to go through receiver, no sound would come out. Am/FM has to be turned up to full volume to even hear it at all - no other components work now - nothing had been touched since first hooking everything up and having them all work. Any idea where the problem might be?
when I connect the subwoofer to the rx-v992 receiver there is no audio,
I have definitive bp 2002 speakers and within the last month both of my bass amps have quit..hard to...
(More)
I have definitive bp 2002 speakers and within the last month both of my bass amps have quit..hard to believe both speakers are having the same problem... could it be the receiver which is a Denon 3808. I have checked everything I know how to check
Plugged my centrex ctdv200 set top box into sharp tv but remote won't work batteries are new
