Question about IBM ThinkPad T30 2366 Notebook
Hidden folder are not visible
I had tried a lot in this case. I had changed the windows directory but it is not changing it. I had install the avast antivirus and it deduts hidden process of 2.cmd but does not deletes it. My sound icon is not shown in tray.
plz help me i will be thankful to u.
  • 25 Answers
Process are not hidden files but a file that is being runned by windows. Antivirus can't delete a process because Windows is using the file. Did Avast detect the process as a danger? If not then don't worry about them.
If your sound icon isn't in the tasbar tray. Go to Start -> Control Panel -> Sound. Here should have check box for volume control icon. Check the box if its uncheck to get the volume icon.
Hope this helps.
Posted on Aug 21, 2008
How to uninstalled the expired AVAST antivirus from my PC?
Normal UninstallThe first thing you want to try is to locate Avast in the Add/Remove Control Panel and try to remove it from there. Follow these instructions to accomplish this.
1) Click on Start, Control Panel
2) Open Add/Remove Programs
3) Find Avast in the Programs list and highlight it
4) Click Remove and follow the prompts to uninstall Avast
Using the Avast Uninstall UtilityIf for some reason the normal uninstall does not work, you may have to download Avast's own Uninstall Utility.
1) Click on the following link and download the Avast Uninstall Utility to your desktop
http://files.avast.com/files/eng/aswclear.exe
2) Double-click on the file ASWCLEAR and run it
3) You should see the following screen
4) Click on the ellipsis and choose the folder where Avast is installed. This folder is usually in the Program Files directory. Ex. C:\Program Files\Avast
Be very careful which folder you choose since whatever folder is chosen will be completely deleted from your computer.
5) Once the uninstall has completed, reboot your computer. You may then try to reinstall it or another antivirus.
If for some reason the uninstall utility does not remove it, you may have to reinstall a newer version of Avast to then proceed to uninstall or you may have an issue where multiple antivirus programs are showing in the Windows Security Center.
Hope this help!
Sep 06, 2011 | AVAST Software Avast Free Antivirus
Uninstalling problem of antivirus software
First.. install a different antivirus program while you are fixing this installation. Try microsoft security essentials or AVG.
Then.
Check your program files folder for any mention of Avast, and delete it.
Run a search for avast and delete anything you find.
Download a registry cleaner, I use CC Cleaner.
Run the cleaner and remove all the files it finds, run the registry cleaner and let it delete all the problems it finds .
IF you want to try with avast again, uninstall the other antivirus program you may have installed. then try with the Avast again
Aug 01, 2010 | Microsoft Windows Vista Ultimate with SP1...
The screen says write protect and so i cant take any photos or delete the old ones... What to do?
Do the foowing instructions please:
1. Turn off your camera.
2. Remove your memory card.
3. Switch the position of memory card.
4. Install the memory card to its own place.
5. Turn on the camera.
I hope this will help you.
Jun 15, 2010 | Olympus FE-370 Digital Camera
Hidden files are not showing
Hi there.
It sounds like you have a virus on your machine, apart from not being able to view hidden files and folders is there anything else thats going wrong with the PC at all?
for example on start-up do you get any strange error messages or has the recycle bin name been changed?
Jun 08, 2009 | Microsoft Windows XP Professional
What happens if we delete hidden directory system volume informat
Hidden directories most often serve to hide important operating system-related files and user preferences. This is mostly to protect the files. But malicious programs (malware, viruses, trojans) can also use this functionality to hide their presence.
The System Volume Information folder is a hidden system folder that the System Restore tool uses to store its information and restore points. System Volume Information (SVI) is the name of the data store where Windows XP and Windows Vista keeps its System Restore files and registration databases. System Restore not only saves copies of critical system files, it also performs automated registry hive backup.
There is one SVI folder per drive being monitored by System Restore. You can not view/access the SVI folder by default but there is a way to make them visible. You might need to gain access to this folder for troubleshooting purposes.
Basically, if you delete the System Volume Information folder, you will no longer have the files and data needed to restore your system to a previous state. For example, if Windows crashes or is stuck in a continuous boot cycle, you can use System Restore to restore your system to a previous "healthy" state. However, if there are no files or registry backups available, this tool is then no longer available to you. Also, if you ever decided to use System Restore, you would need to re-create the foler in the same path so that the system files can be stored there again.
Hopefully, you backup your system and keep good backups often...
Apr 13, 2009 | Microsoft Computers & Internet
Not able to open regedit!
Hi, you do have a virus and or trojan.
Please download Malwarebytes anti-malware from http://www.malwarebytes.org When you download choose save to disk and rename the file to anything you like, The reason for the rename is many newer trojans can identify malware removal tools and prevent them from working as well as disabling you regedit and task manager.
Let anti-malware install and update and perform a quick scan.
When its finished have it remove what it can. If it asks to reboot do so.
When you have restarted your computer download Avast anti-virus
from avast.com again renaming the exe when saving to disk.
After install it will ask if you wish to schedule a boot time scan select yes. Then it will tell you to restart your system, choose restart later. Open avast from the start menu and select settings. Go to updating and update the virus signatures. Restart your computer when the update is complete.
You have to watch the screen as avast will alert you and ask for your preferred action on what it finds.
When completed your computer will boot normally into Windows run both scanners again in the same order.
Good luck
Apr 09, 2009 | Microsoft Windows XP Professional
I get a backup, but with a lot of error messages
Microsoft has some hidden directory levels and files in VISTA and in XP that are visible only when the settings for the directories in which they exist are changed from the hidden setting.  It's tedious, but possible.  I assume, then, that what you were unable to copy to your backup are these hidden files.  They're placed that way as a default in the Windows install to protect the user from accidental "mistakes". Example:  Under "users", {name},AppData,Local,...
Dec 17, 2008 | Maxtor OneTouch 4 500GB External USB 2.0...
Hidden files are not visible
start ----- run ----- regedit -------- HKEY_ LOCAL_MACHINE ------- software -------- microsoft --------- windows -------- current version ------- explorer -------- advanced ------- folder ------- hidden --------- showall
there we check DWORD VALU of CheckedValue = 0 for not save
1 for save(by defult)
Feb 25, 2008 | Microsoft Windows XP Professional
IBM ThinkPad T30 2366 Notebook Logo
49 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
