Question about Philips Magnavox 27MS343S 27" TV
Philips Magnavox TV TS 3260 C121
When I turn on the TV, a pink screen slowly appears with horizontal lines that quiver and then the TV turns off by itself.
Help!
SOURCE:
  • 1694 Answers
SOURCE: Philips magnavox 25tr19 c121 problem
Still need info..? Can you replace soldered in parts.? Let me know.........................T.
Posted on Dec 23, 2007
  • 125 Answers
SOURCE: Magnavox 27 Inch TV- no picture but has sound
the vert. circuit need to be rebuilted
Posted on Aug 06, 2008
  • 126 Answers
SOURCE: philips magnavox smart series pr1920c601 turning off itself!
well let me ask ya something so it is coming back by its self then going back out may be solder connection okay call tv shop good luck shad
Posted on May 03, 2009
rulds2008
  • 3866 Answers
SOURCE: horizontal grey lines and tv cuts off by itself after 10 sec
Anyshop would take this under coinsignment as a bad Horizontal IC
"intergrated circuit"
But do not shoot the messenger, its going to need a shop, I would not recommend you opening this unit and risk a fatel shock or Death. Just the flyback transformer alone could kill you. Not to sound harsh but please understand, I do not want fixya to be on the late night news that it gave someone a solution that could have caused injury or death, if your not experienced take it to a shop. You cost if it is a IC witch it sounds like to me your looking $75-$100 parts and labor.
Thanks for your intrest in fixya.com please do rate and leave feedback.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jul 13, 2010
Testimonial: "honest info...doesn't get any better than that! Thanks!"
robotek
  • 1512 Answers
G'Day,
The grey lines you describe, sound like retrace lines. There will be a problem in either the screen voltage drive stages, or possibly power supply regulation causing this. If the set had a "horizontal IC" problem?? you would not get much on the screen at all as the horizontal(flyback) stages would not be operating. You need to be at least scanning to get the lines across the screen you mention. The set is shutting down to prevent any damage occurring. This repair will take a TV tech to solve for you, and as the replacement cost,and age of the set, at least 7-8 years... repairs could be considered uneconomic if costs were to exceed $150. Get a free quote from a repair guy near to you.
regards
robotek
Posted on Aug 04, 2010
Audio decoder section circuit fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 22, 2016 | Philips Magnavox 27MS343S 27" TV
PHILIPS MAGNAVOX PS1963 C121
Hello
"Philips Magnavox PS1963c121". That is all. What shuld I do with It? Please give me details of it problem. Without it what should I do?
Jan 06, 2011 | Philips Magnavox 27MS343S 27" TV
Magnavox tv model ts 2543 c121 volume control goes to high and you can not lower it..when you do it goes right to high
does the volume indicator on the screen appear?if it is then you should clean the volume buttons of your tv use a contact cleaner to clean the volume switch .spray the cleaner on the buttons and repeatedly press the buttons to clear the poor contact.
Jun 13, 2010 | Televison & Video
Reference to Phillips Magnovox Model PR1302 C121.
turn on tv,it turns back off,without lighting screen.
May 04, 2009 | Philips Magnavox 27MS343S 27" TV
Tv Philips Magnavox won't turn on
Its Broken And Now Dangerous i would not even try getting it fix. That burnt smell is never a good sign
Sep 07, 2008 | Televison & Video
Magnavox resistor problem
The CRT board is the one that connects to the back of the CRT.
Follow the 200VDC line to locate the burnt resistor, is normally a low value fuse resistor.
Apr 15, 2008 | Philips Magnavox 27MS343S 27" TV
Philps TV problem
When I turn the TV on, I get a horizontal line across the screen approx 1/3 from the top. My TV make is Diamond and is approx 6 yrs old
Mar 14, 2008 | Philips Magnavox 27MS343S 27" TV
Nov 16, 2007 | RCA F31672ET TV
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Philips Magnavox 27MS343S 27" TV Logo
182 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
