Question about Sony KLV-S32A10 32 in. HD-Ready LCD Television
TV cannot start up I have a projection HD SONY Model no KL-37HW1 bigscreen, my daughter somehow pussed buttons on remote and tv is in sleep mode, can't power up just the power on/timer lit is blinking...tried every button on remote. There is not CHILD lock button in the remote. Can you please help me out. Thanks
  • naveen_sharm Aug 24, 2008
    I tried this solution cant work out.
    In addition i want to tell that whenever i switch on the TV, relay sounds comes for 3 time.
    Please suggest
    Thanks
  • joellasolis Oct 14, 2008
    keep trying to change chanel and cant
I tried this solution but cant solve the problem. Every time TV goes to stand by more. One more point i want to tell that if i switch on the TV power button, relay sound comes for 3 times.
Please suggest
Thanks
Posted on Aug 24, 2008
  • 876 Answers
Http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C243178&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=9180848&stateId=0%200%2012107423
Try this link.( You'll need to copy and paste it into your address bar since it is so long.) this may be just what you need. Your remote control however may need to be reprogrammed, so I would look for the manual download for your Remote using the model # of the remote, Unless you are using a service procided remote, and then you would need to find the information in that manual (Direc Tv, Comcast, whatever.)
I hope this helps. Thank you for using Fixya
Posted on Aug 21, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 24, 2008
    Try this: Turn on the TV.
    While holding down the (UP arow) on the Remote, press Power on the TV. The TV should turn itself off ten back on again. Release the (up arrow button) This is a factory reset and will clear all customized settings.
    I hope this helps.!
SOURCE:
Sony KL-50W2U rear projection TV stuck in standby
Try holding down the power button until it turns off and then turn it on again.
Nov 29, 2012 | Sony KL-50W2U
SONY HDTV-LCD MODEL - KDF-42WE655 turns itself off. Lamp light indicator flashes red. Should I attempt to reset ? It is approx. 4 years old
I'd wager that somewhere in the menu settings, there is a "Sleep Timer". Check the menu for the sleep timer, which turns off the TV after a set length of time. Also, check your remote, there might be a "Sleep" button that would do the same thing, press it multiple times until it reads "Sleep: Off" or something similar.
Dec 19, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture
your sony ctv is in sleepmode. so kindly press sleep button at remote control .other wise you swith off tv ( that means remove the mains wire from pluck point) then after 5 minutes switch on it will OK.
Aug 02, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Deep sleep mode on digital tv
We turn off the TV. Turned it back on using the tv turner remote that comes with the set, we push the HDMI1 mode button immediately! Must do before it goes to Deep Sleep mode. You should not use RGB mode as this will cause the problem to repeat. (Vizo HD 50") Keep trying if doesn't work the first time. You have to be ready and quick to get the mode HDMI1.
Oct 28, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Had a universal remote for my symphonic wf2703 tv my daughter tryed to change something with the remote now plays the dvd player ok turn it off all that comes up is a black screen with video on it the...
I had to clean the sensor area for the remote on the tv somehow got something on it. I wonder how, my little 4 yr old daughter had know idea how it got there lol.
Aug 01, 2008 | Televison & Video
JVC HD-52G786 Service Mode
Sure. I'm not sure if you can do it without the original remote, though. On my remote, you need to have the tv turned on, then press the sleep timer, then press the display and video status buttons simultaneously. This enters the service mode. Then, you should see an option for self-check (#2 i think). Enter that, then you should see 2 vertical columns of different inputs. From that screen, power the tv off. This resets all the ports on the tv.
Jun 18, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Have an older model Sony Trinitron TV w/o original remote. TV is on "sleep" mode and we are unable to get it off that w/o the original remote. What can we do?
try this link they may have the origional remote and they offer fast shipping. just enter the model number into their search box. www.replacementremotes.com
Apr 02, 2008 | Televison & Video
Trying to use sleep mode, no manual or original remote
do a google search on the model of your tv..and you will find the original remote available most of the time for only a few bucks..........
Feb 03, 2008 | Philips 55PW9363 55" Rear Projection...
Sony KLV-S32A10 32 in. HD-Ready LCD Television Logo
117 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
