Question about Hitachi CP-X345 Multimedia Projector
Completely dead When I connect the power cord and flip the power switch, there is not activity at all. No lights, no fans, no projection, nothing. I have tried pressing the "restart" button, however the manual doesn't describe the "restart" process much at all. Will I need to have the unit professionally serviced?
  • Hitachi Master
  • 3,051 Answers
You can open it up and see if the fuse inside is blown
Posted on Aug 21, 2008
RCA P52810lv will not power on
Completely dead with nothing suggests maybe a blown or open fuse--first step would be to unplug and look for a fuse--follow the power cord.
Jun 11, 2012 | RCA Televison & Video
Alesis 620 M1 active no power no light
You just fix the power supply and Brige and check the transformer
May 18, 2012 | Alesis M1-Active MkII Main / Stereo...
The unit is completely dead. no lights and no fan. Both fuses on the board are good.
If it is dead, and doing nothing at all, have you checked to make sure its not a power failure to the unit? Sounds to me that may be a problem if all is dead. You probably checked this first, but make sure. I repair wine coolers, walk-in boxes on a day to day basis, and if you have no lights or fan, and nothing at all is coming on, it is either a power failure coming in or the power cord its self has come loose to the control section. That's all it could be, you have lost power. Check for power at the board if you have power to the outlet. The reason I believe you have no power to the unit is you say the light and the fan are off, and nothing is working. Please check and let me know.
Sincerely,
Shastalaker7
A/C, & Refrigeration Contractor
Jun 07, 2011 | Cuisinart CWC-1200 Wine Cooler
I have a hp desktop about 5 years old..few days ago we had a power outage. power came on and off a few times ..i wasnt home but my pc was on when i came home my pc was off and wouldnt start..i try to push...
> bad power supply
Try an ordinary lamp in the wall-socket -- to make sure that a circuit-breaker inside your home has not "tripped", i.e., no power to anything that plugs in.
If there is an on/off switch beside where the power-cord connects to the power-supply, switch it to the "off" ("zero") position.
Unplug the AC cord from the power-supply.
While watching the fan inside the power-supply, and/or watching the fan on top of the CPU, plug-in the AC cord. One of the fans may "twitch", if there is power.
Flip that rocker-switch to the "on" ("one") position, and see if one of the fans "twitches".
Also, look on the motherboard for a small lamp -- it may go on if the AC power-cord is connected,
or may go on when that "back" switch is set to "on".
Try a different power-supply. If still nothing, then it's your motherboard that got "fried".
Nov 11, 2010 | HP Pavillion s7420n PC Desktop
System dead - checked switch, changed Power supply
Your motherboard has been faulty.you can repaired it from service center.
May 10, 2010 | Computers & Internet
Sounds like either you have a faulty memory stick, faulty CPU or CPU fan or a faulty Mobo..
Mar 16, 2010 | Computers & Internet
Laptop wont power up
This is what I would do before chalking this thing up as a hard ware failure try connecting thie to another adpator if that then does not work you indeed got a HW failure with the laptop and the motherboard would likely need to be replaced, Get it evaluated by a technition the geek squad at any best buy wull be able to test this real quick for you do not loose a good laptop over a faulty adaptor trust me this is where the issue could result.
thanks and please do leave postive feedback, ratings for your free naswer today.
Nov 17, 2009 | Advent Netbook
Refrigerator no power
Plug some other device into these same outlets or use a volt meter to verify power at the outlet.
You definitely have a house wire problem if the interior light does not come on and the bulb is good.
Also check 120 volts power at the fridge cord where it attaches to the terminal box.
Feb 21, 2009 | GE PSS26SHRSS Side by Side Refrigerator
Dell Inspiron 8500 no lights, no fan, nothing.
First remove the battery and try it. If it works without the battery, then that is the problem. My Inspiron 2650 suddenly started acting like that with the battery in but works perfectly without the battery.
Whenever you replace a battery ALWAYS let it completely charge BEFORE you try to use the computer with the battery in place.
Do the POWER, DISK ACTIVITY and/or BATTERY CHARGING light stay on?
If so try powering the computer off; unplug the power cord; remove the battery; carefully remove the RAM modules; check the connections for corrosion/dirt; them reinsert the modules; close up the case; plug the power cord in and try powering it up without the battery inserted to further eliminate the battery as the problem.
If you get NO lights or fan noise without the battery installed, you probably have a mother board problem, most likely in the power switch. With the 2650s the switch is an integral part of the motherboard (DELL calls them system boards I believe) and DELL recommends replacing the board. I guess if you can find someone brave enough to work on the board, you could fix the switch because DELL refurbishes them and if the board isn’t working anyway, then you have nothing to loose.
I hope this helps you. Good luck. The 8500s are good computers if you get enough memory in them.
Don Jones
Jan 25, 2009 | Dell Inspiron 8500 Notebook
E-Machines 2862 Dead On Power-Up
I believe that the front button is not connecting to the switch for the power supply. Also make sure all internal connections are secure. Sometimes the button breaks from behind so that it cannot contact the switch. Let me know if it helps. There are other solutions if you tried this one first.
Nov 01, 2007 | E-Machines T2682 (000002965) PC Desktop
Open Questions:
Hitachi CP-X345 Multimedia Projector Logo
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
