I have a Lexmark T420 that I want to connect to my new laptop (HP) via a parallel to USP. The print drivers will not load. What do you suggest?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you have Vista Drivers for your printer?
    I've never used a USB to Parallel cable before but does that usually need a driver to use as well?
  • 197 Answers
Does it have to connections to the printer like a usb and a paralel cable, this is a cable that has two big ends on it and just a straight cable . if there is you might be able to do this by usb, and it will also depend on what os you are useing
thanks
hope this works for you
Posted on Aug 21, 2008
I have a citizen prolaser 6000 laser printer, it emulates HP Laserjet 3, I want to connect it to my laptop via a usb interface cable, currently it is connected to the printer port of a desktop (lpt1 for...
There is three things that you will need:
Proper port set up on laptop device manager (Check settings) LPT1 is for a parallel port - Need USB Correct Driver for the Citizen 6000 Pro Laser (Windows should auto install) Hub that will communicate via USB to the IEEE 1284 Printer via cable.
Driver Site: http://www.driverfiles.net/Printers/Citizen/Prolaser-6000-Printer-Driver/download/page,sh,38839,389,12,.html
I hate to suggest, but you may have to call Microsoft Citizen Tech Support for suggestions on the Hub that will communicate via USB properly. Check your manual for setup options.
TF
Jun 02, 2011 | Office Equipment & Supplies
I have an HP LaserJet printer 4050N with RJ45 and Parallel Port. The Printer is kind of far from the WireLess router and I can't connect it. Unfortunately, my PC doesn't have a parallel port. The best...
Another option is to find an old laptop, with "wireless" capabilities and a Parallel Port.
Connect the printer to the laptop.
Connect the laptop to your wireless network.
Tell the laptop to "share" the printer.
Then, any computer on your network can "find" the networked printer, and can print to it.
Jun 12, 2010 | HP LaserJet 4050 Printer
I have a HP Laserjet 4P that had been used on my company laptop and home computer. When I upgraded top a new Dell Vostro 420 running Windows Vista Business and moved the printers over to this unit the...
You don't write how exactly is your printer connected - if I remember correctly, HP LJ 4P doesn't have a USB connector, and Vostro doesn't have the parallel port available.
So how did you connect it? Is it via some USB to parallel adaptor, or via JetDirect network card in the printer? There are multiple separate issues that may be applicable in either case...
Dec 30, 2009 | Office Equipment & Supplies
Lexmark X4550 not printing in Vista can't enable bi-directional
"Bi Directional Printing" is a statement of Parallel Port printing. Are you connected from your PC to the Printer via the parallel port?\
Did you disconnect the USB cable form the PC and then delete the current driver prior to installing the Win 7 driver?
Nov 18, 2009 | Lexmark X4550 Multifunction Wireless Color...
Just purchased an iMac computer for my HP DeskJet 880C
You can log on to the hp site and get the current driver/printer software for your printer. Get the mac os version and install via usb. Download and install then restart your imac... then attempt a print...
Should work fine with an iMac.
K
Sep 01, 2009 | HP DeskJet 880c InkJet Printer
Need to use HP Deskjet5550 to print off laptop
Since Hp have Vista driver to your printer...to install the driver...do not plug the printer...install the driver that you downloaded (run the program as Administrator)..after you install, if the installation ask for restart..restart your computer...after restart and the whole system finish his task on loading driver and dll ..then plug in your printer...it will pop up message found new hardware. click next and choose automatic find the driver.
what Cable are you using to connect?
USB a and b?
parallel port to USB? if this you need to download the driver too.
Good Lock
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
I have a new Compaq laptop running Vista home and an old samsung 4216f. I tried a parallel to usb and cannot get the printer to work. No parallel ports on laptop and no usb on printer. Any ideas?
If you have a home network, try a Print Server with parallel port. You will connect the printer to the print server via parallel, and the print server to a network hub/switch/router (any of the listed) via a network cable, and the computer to the hub/switch/router via network cable or wireless.
Cost should be around $20 - $60 depending on make/model.
Nov 30, 2008 | Office Equipment & Supplies
HP Printer 350C C2697A
well, some times the driver is the cause of the problem, try to change the driver or shearch the web for someone, and if you have win2000, try to install windows xp or windows 98 driver
Jul 12, 2008 | HP DeskJet 350c InkJet Printer
Lexmark z11 Vista Compatible?
Looks like I've cracked it [Touches wooden desk]. Need a USB to IEEE 1284 36-pin Parallel Printer Cable, like the one I received today (ordered yesterday from www.cables2u.co.uk). First, connect it to Z11. Turn on Z11 and boot up Vista PC/laptop. (I run Vista Business on my laptop.) Connect cable to computer. Message appears "Installing device driver software". Click it for status. 'Found New Hardware' box appears. Click 'Locate and install driver software'. A message appears "Error loading LXADSUI.DLL. Specified module could not be found". Click 'OK'. Message appears saying driver software installed successfully. ["Yeah, right ..."] (Have faith, folks!) Now, click Start, then Control Panel and double-click Printers. Right click on Z11 and click on Set As Default Printer. Right click on Z11 again and click on Properties. Check on Ports tab that Port USB is ticked for Z11. On Cartridge Maintenance tab, check right cartridge is showing. If not, click 'Install/Change Cartridge' and follow instructions. Then 'Clean Print Nozzles' and 'Align Cartridges'. Check settings on the other tabs in Properties look OK and try printing a test page! It looks good to me!
Jan 15, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
