Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Waste ink warning
I tried your solution but it didn't work for me. On my menu I get service report,#1 SSSW, #2 menu, #3 Numeric Param., #4 NCU, #5 Type, #6 Genesis UHQ, #7 Printer, #8 Clear, #9 Rom, #10 CS Set. It never says "counter". Could you give me every single detail to this process. I must be missing something. Thank you
  • dchagans Sep 08, 2008
    Thank you so much. I did exactly as you said and my printer has stopped flashing the "wast ink tank full" message. Can you tell me is there a way that I can empty the waste ink tank????
You press menu, copy, #
you will enter service mode.
then go over to TEST mode press set.
press 8, then 3, then 0.
Ink counter will be reset.
Then press the on/off button and it will go back to normal.
Hit Menu, Copy, #.
Go to #8 Clear, then you can access with the plus and minus buttons all functions you can clear.
Posted on Sep 04, 2008
Why is alarm light flashing? 5800
The ink absorber is full,The waste ink error is based upon time instead of actual volume in the tank. You can reset the counter by the instructions below.
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the STOP/RESET button, then press and hold the POWER button.
(3) Release the STOP/RESET button, Next press and release the STOP/RESET button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the STOP/RESET button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!)
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Dec 18, 2015 | Canon PIXMA MX310 All-In-One Printer
How do I replace wast ink tank on canon pixma mp 780 printer
Hello! here is your solution.
1) Press the following keys in sequence: Copy-Menu-Scan-Copy-Scan.
The display will say:
SERVICE MODE
#1 SSSW
2) Press the > key (also labeled +) six times.
SERVICE MODE
#7 PRINTER
3) Press OK.
#7 PRINTER
#1 SSSW
4) Press the > key (also labeled +) four times.
#7 PRINTER
#5 INK ABS CAPA
5) Press OK.
SUCTION
XX (where XX is how full the waste ink tank is as an integer percentage)
Sep 01, 2011 | Canon Office Equipment & Supplies
The waste ink absorber is full. I removed the sponge, rinsed and dried it and put it back in printer and reset the ink counter. I cant get the printer light to change off orange. Unable to finish the...
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in
"Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp
(More selections beyond this point) - However it is best to leave them unaltered - You have been warned!
Jan 03, 2011 | Canon PIXMA iP90 Mobile Printer
HAVE CANON F60 MULTI PASS. ERRPR IS WASTE INK NEAR FULL SEND BACK TO CANON WHY CAN'T I REPAIR IT MYSELF
It is not recommend you try to fix it yourself, you can try to manually reset the error code, but if the waste ink is really nearly full and you reset it, it could damage the printer pretty severely. Here are manual reset instructions for a similar model printer, it should work on the F60 if the buttons are the same:
1) Enter Service mode by pressing: menu-copy-#
2) select: Test Mode
3) select [8] printer test in test mode
4) select 3 [eeprom clear]
5) select 0 [ink count]
6) press the [stop/reset] key (returning to the state of 3), and press the [on/off] key
If that doesn't work try this one:
1) Enter service mode by pressing MENU,COPY,SCAN,COPY,COPY
2) Select TEST MODE
3) Select (8) PRINTER TEST in TEST MODE
4) Select 3 (EEPROM CLEAR)
5) Select 0 (INK COUNT)
6) Press the SET key
7) Press the (Stop/Reset) key, returns to the state of 3, then press the ON/OFF key
Sep 15, 2010 | Canon Office Equipment & Supplies
How do you get into service mode on canon MF6560 (image class) ? Thanks RD
Press “Additional Functions”, “2", “8", “Additional Functions” in succesion.
Display will show “#SSSW”.
Press “+” or “-“ key repeatedly to go through the following menu list:
#SSW, #MENU, #NUMERIC, #SPECIAL, #NCU, #FAX, #SCAN, #PRINT, #NETWORK, #CODEC, #SYSTEM, #ACC, #COUNTER, #REPORT, #DOWNLOAD, #CLEAR, #ROM, #TEST MODE
Don't make adjustments in these modes unless you know what you are doing; could mess things up. Counter mode is especially helpful though for observing the performance (totals, mode, feed, and jam counts).
Jan 11, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
My Canon MP830 Printer will mot work. Alarm blinking and copy light blinking . How do i FIX? Dr.s' office...help!!
Canon MP750, MP760, MP780, MP830
The Unset mistake:
##341. Maintenance jet waste ink capacity full
##342. Cleaning absorption waste ink capacity full
##343. Ink detection waste ink capacity full
1. Include the printer.
2. Press button Menu , then Scan , Copy and once again Scan (entry in service mode, on дисплее will appear #1 SSSW)
3. The Arrow to choose 7. Printer test , press Ok .
4. The Arrow to choose 5. Ink abs capa , press Ok , install importance 0 .
5. Switch off the printer.
Sep 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Continue printing greyed out
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Jul 01, 2009 | Canon PIXMA iP1600 Printer
The Waste Ink tank is full
go to www.neilslade.com/papers/inkjetstuffll..htl
scroll down to 370
CAREFULLY FOLLOW INSTUCTIONS
1st remove USB cable
take your time BETWEEN OPPS
print out ???????????????????????instruions FIRST
hit the red triangle followed by scan copy scan
you should now be in service mode
now slow down it is not fast
dj
PS your tank is a bin and could over-FLOW on to your nice sheep skin RUG=warning
Jan 26, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Canon mp730 Error message
Dear sir,
physically you can't replace that part ,its a EPROM counter, which shows you the error message .you can only reset the counter through that procedure.otherwise if you want to replace that part then you have to contact authorised Service centre , to replace that part.
Regards
Dec 17, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
How to reset waste ink absorber full ip3300 warning?
Try to enter service mode and reset EEPROM:
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head
Press RESUME 4 times then POWER to execute the command
turn the plug off turn on and all ok
Dec 13, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
old marine
old marine
