Afficio 450 seeting
What will be the best seting for afficio 450 if i will use refill or replacement toner for my machine....
  • 2,794 Answers
Auto setting. If you are getting light copies, you might need the developer replaced as well.
Posted on Aug 21, 2008
  • 162 Answers
If changing the developer after a time the copy returns to be clear, try
adding to toner with 2 207 forced toner supply, Until reaching the wished copy.
Later changes change the value: 2 802 1 to 3.5 V maybe 3.0 try Lowering this value until reaching the wished copy.
Posted on Sep 13, 2009
  • Delfor Tomás Acosta Sep 14, 2009
    Now the
    best thing is to work with toner of good quality if he is possible original
Afficio 450 developer type 4 or type 5
This machine takes Part Number "887733: Developer Type 5"
Hope this helps.
Jul 05, 2009 | Ricoh Office Equipment & Supplies
Changing developer unit in afficio 450
Remove PCU, remove development unit, remove cover (2 plastic C-clips) remove filter, remove development roller (2 shoulder bolts). Clean roller and empty all developer. Pour in new developer, re-assemble unit. Reinstall drum and Development unit. Place a small piece of paper between the PCU and toner entrance hole to prevent used toner from entering dev. unit during calibration. Perform SP2-801. Remove paper form dev. unit
Apr 24, 2009 | Ricoh Aficio 450 Copier
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
Mar 02, 2009 | Ricoh Aficio 450 Copier
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Jan 26, 2009 | Ricoh Aficio 450 Copier
Afficio 450 copy faded in some area...
If the image is good in parts, but light in others it is most often toner build up on the laser exposure glass which can be easily -but also VERY CAREFULLYremoved. If you lift the green handle for the toner bottle, you should see a narrow piece of glass protruding just underneath. You can grasp it with you fingers and slide it out for cleaning. Sometimes these have been removed (or broken) so they are not there. If the machine is also a printer, you should see much improvement (if this was the cause). If regular copying is still light in areas, then you may want to remove the copier glass - 2 screws on left scale, and 3 screws on rear scale (POWER OFF ON MACHINE), remove glass and clean with glass cleaner, then slide scanner to the left and clean the mirrors.
Hope this helps.
Jan 17, 2009 | Ricoh Aficio 450 Copier
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Fuser..?? afficio 450
The fuser probably will not help. I think you probably will need a PCU, and a service call.
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
74 people viewed this question
