Question about Canon PowerShot SD1000 Digital Camera
Camera will not power on.
My Canon SD1000 will no longer power on. I have 2 batteries for it. I have charged both up fully (the light on the charger turns green) and tried both batteries. I have cleaned the contacts on the batteries with a dry Q tip. The contacts look very clean. The camera was working beautifully one day and then in the same day it failed to power on and remains this way. The camera has not been dropped. The camera has not been wet. What do you think is wrong with it. It is just out of warranty. I purchased it in May 2007.
Thanks,
Jeremy
  • 5 more comments
  • jennifern09 Aug 24, 2008
    Mine too! The battery was completely charged. I took a picture, put it back in my bag. Then i took it out again a minute later, and it stopped working completely. It was not dropped or ever wet. Help please!
  • griffin7 Aug 31, 2008
    yes, mine was working.  i turned it off and it never came on again.  What a waste of money! it's less than a year old.  I won't buy canon products again, they are rubbish.
  • madallyn Aug 31, 2008
    how can i reinstall the firmware on this camera SD1000? My computer do not have driver for that.
  • maryfish18 Oct 30, 2008
    same problem! It just will not turn on and wish I knew why. The camera is only 1 year and 1 month old (of course it is just shy of warranty coverage) and was never dropped or mishandled. How frustrating!
  • bananarose Dec 12, 2008
    same here! one second i was uploading my pictures then the moment i unplugged the camera it shut off and has refused to turn back on since. I even took it to Geek Squad at Best Buy. They took it for two weeks and told me they fixed it, but it still won't work!
  • hung4t Jan 15, 2009
    Mine too. My daugther dropped it and it did not work after that.
  • qazwsxky Feb 28, 2009
    Exactly the same for me on the SD1000. I think it may be the fuse as it happened when I plugged the cable into the USB. Anyone know how much it is to fix? Probably not worth it, good excuse to buy another camera though!
  • 734 Answers
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Posted on Dec 04, 2008
When i try to veiw photos the camera turns off Canon Powershoot SD1000
Ensure that the battery is fully charged. If the battery is fully charged and the problem continues, export all the photos to a computer and format the memory card.
If there is an issue with the memory card, formatting may resolve the issue.
Mar 01, 2011 | Canon PowerShot SD1000 Digital Camera
With a fully charged battery, how long does the power shot sd1000 work in movie mode?
It's not just the battery that counts...you will get better and longer results with a class 6 card or better.
Jun 19, 2010 | Canon PowerShot SD1000 Digital Camera
Canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
  • Direction of your battery might be wrong, Check out and put it again.
  • Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
  • Check whether Memory Card/Battery Cover is properly closed.
  • Load new or fully charged battery.
  • Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 05, 2010 | Canon PowerShot SD1000 Digital Camera
Battery not charging
the charger light detect the battery level charge, shows red when charging and green when fully charged.when the charger light is not lit,may be the battery dosnt hold any charge that means its likely that the battery is defective
Dec 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Flash Does not work. canon sd1000
This happened to my SD1000 and I followed the step by step instructions shown here:
http://www.ifixit.com/Guide/Replacing+Canon+PowerShot+SD1000+Broken+Flash+Unit/7778/1
and when I got to step 15, I found that the small plug that connects the flash to the camera body had been disconnected when the camera had been dropped. I simply pressed the connection back in tight and reassembled the camera - and it works. Maybe this happened to yours too??
Dec 10, 2009 | Canon PowerShot SD1000 Digital Camera
My Canon Powershot SD1000 has a fully charged battery but won't turn on at all.
Does your camera turn on when it's in playback mode? I have a similiar problem with mine. It only turns on in playback mode.
Sep 25, 2009 | Canon PowerShot SD1000 Digital Camera
Will not power on or charge
This is a common issue with the sd1000 1 of 4 things can be wrong bad battery, blown fuse, or bad battery door switch or a bad main board. repair on your camera run any where from 45.00 to 90.00 to be repaired.
May 26, 2009 | Canon PowerShot SD1000 Digital Camera
Camera Frozen - Canon Powershot SD1000
Have you tried using a different set of batteries ?
Mar 05, 2009 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
187 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
