Wer can i get service manual of afficio 450 free
Elow can any give me link wer can i download the service manual of afficio 450 so dat i can fix my own copier big tenk ....
  • thraser
    thraser Aug 21, 2008
    how about the service manual to repair affcio 450... or the service code (SC) meaning so dat i can fix my own copier....
  • 876 Answers
Http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
The manual is in PDF format, however on the same page is a link to download the free acrobat reader if you don't have it so you can read this manual.
Please rate this solution and thank you for using Fix Ya!
Posted on Aug 21, 2008
Parts and consumable of afficio 450
http://www.ricoh.com.ph/support/contact.html
Sep 07, 2009 | Ricoh Aficio 450 Copier
Afficio450 replace new developer unit wat procedure to be follow?
No, the 450 is just one of those machines that seem to have PCQ no matter what you do. Given light copies, I'd replace the drum for sure and make sure your ID sensor isn't covered with toner. Dust covered optics will also cause light copies on this model.
Jul 25, 2009 | Office Equipment & Supplies
Wat is da problem of my copier afficio 450
Thraser, your still battling this machine? Of course your readings will be off if you only have developer coverage over half the mag roller? That's where I would start.
I also now wonder about your model #, because I don't think that the 450 has a VSDP reading, but the newer ones do. It refers to the "immediate post-pattern output" of the ID sensor -not surprised that these readings would be whacked!
Mar 05, 2009 | Ricoh Aficio 450 Copier
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Changing developer in afficio 450
Preform SP 2-801 then 2-805.That will do it!
Jan 21, 2009 | Office Equipment & Supplies
Copier.... afficio 450 vs konica 7025
You're talking about two really old machines, the 450 from 1998 & the 7025 from 2000.
Both are about the same class, but I'd give the edge to Ricoh since it was also sold under a number of other brands & replacement parts are readily available.
Hope this helps...
Sep 10, 2008 | Office Equipment & Supplies
Afficio 450 programs....
You have to have all the firmware in order to able to do that. It comes on a PCMCIA card that you plug into the copier. If you format the hard drive, there will be no way of getting the programs back unless you have that card.
There tough to get but I found a few of the cards on EBAY. Once you get that, then it's a matter of getting a hold of the software (if it isn't on the card already).
Aug 26, 2008 | Office Equipment & Supplies
Afficio 450 camera lense alignment
You need a manual to calibrate the scanner do you have one?
There are some holes in the scanner that need to be calibrated with a tiny screwdriver. The manual teslls you the correct settings.
Did yiou remove the cable?
Aug 19, 2008 | Office Equipment & Supplies
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Fuser..?? afficio 450
The fuser probably will not help. I think you probably will need a PCU, and a service call.
Jul 20, 2008 | Ricoh Aficio 450 Copier
180 people viewed this question
k24674
jasbo
jasbo
