Coleman gas H/A not shutting off
I put in a a new thermostat today a simple 2 wire unit CT-30 ...Unit works but will not shut off when I change the temp control.  Could sawdust get inside major unit in closet & cause this problem? Thanks!!
  • ebysan Aug 27, 2008
    I had a Heating & Air repair person check unit... The Blower comers on automatically when the house temp. reaches 90 degree in a Coleman Unit.  I did not know this.  The unit was humming . He replaced the Relay switch...He re installed my original Thermostat & all is working well.  Thank you so much!
  • ebysan Aug 28, 2008
    I am selling the mobile home & I wanted everything working well when the Health & Safety Inspection was done..  All is working well.,.Thanks for the information!
    Problem Solver:
  • 9 Answers
Yes and No. Sawdust even when in get in internal parts will not cause the problems that you are experiencing. More than likely your sencondary thermostatic control for the condensor is not set at proper settings to work proficiently with external thermostat.
Posted on Aug 27, 2008
  • fosterb9 Aug 28, 2008
    Sorry, about having to call a repair person. It can be costly.
We have a Coleman Electric Furnace Serial # AOL6042086, Model # AHP36C3XH21A and the fan runs constantly, will not shut off. We have replaced the thermostat and just replaced the control board. We h
I wish I was a furnace expert but I will give a push in the right direction. When a gas/electric fan runs it has two speeds. When you turn on the FAN ON switch it should run at the slower speed. If it doesn't turn on or turn off again when you turn it back you have a wiring problem or a thermostat problem. Make sure the thermostat is compatible with your unit and wired properly (on both ends). The other time the fan runs is "in session" when heat or cooling is applied to the system. It should run until the system finishes the cycle then a bit more (30 seconds or 1 minute) to blow the treated air completely through the ducts. If it doesn't stop then you may have a bad fan time delay or relay. Check parts for your model and various appliance repair site online.
Nov 25, 2014 | Coleman Mobile Modular Home Electric...
Our fan for the intertherm p3ra-024k will not shut off. We have put new wiring from thermostat to unit. He pulled the green wire like the serviceman told him to when he serviced it and it still keeps...
You have a problem with the wiring somewhere it could be in the thermostat. When the service man said pull the green wire off that was the power to the fan. The thermostat should wire up as red to the R terminal on the thermostat this is the 24 volt feed to your thermostat and to the unit. The white wire should hook up to the W terminal on thermostat. This white wire is to the heating section of your furnance it activates the heat mode. The yellow wire hooks up to the Y terminal on the thermostat this is the outside condensing unit control for the a/c. The green wire should hook up to the G terminal on the thermostat this is your fan wire that activates the blower in your furnance If this wiring isn't hooked up as such then your problem is in the wiring from thermostat to units inside and out. Also if you have changed the thermostat you need to be aware of the setting for the thermostat and the type unit you have. Most thermostats are universal however, you need to make sure that on the thermostat the setting for heat pump on the thermostat it will have a small switch and on switch will have hp at the top and nonhp at the bottom. If you have a heat pump you need to make sure that the setting on the thermostat is on hp if not a heat pump nonhp is the setting. Also there will be a switch that has g at the top and e at the bottom This is you gas or electric heating seletor switch make sure this switch is in the proper position for either gas or electric heat. Good luck on your repairs Hope this helped
Dave
Nov 02, 2009 | Intertherm P3RA-024K Air Conditioner
I have a coleman ac unit is about 8 months old.Everything was fine until my $800 dollar bills started to come in the out side ac unit shuts off after cooling the house to the right temp, but the in side...
You may need to check the wiring between the thermostat and the inside unit. Also check the wiring in the inside unit. It sounds like you may have a jump between the 24-volts hot and the control for the indoor fan.
Aug 02, 2009 | Heating & Cooling
Coleman A/C-Heat Pump Start and Stop Run Problems
well you have it great job! on the out door unit when it will not shut off disconnect the yellow wire on the stat wires coming from inside if unit stops stat bad if not contactor "points' if they look pitted or buzz change them #1 reason for compressor failure high amp draw thru bad contactor hope this helps aboout 15.00 at hvac store seperate wires with zip ties so dont get mixed up if only one set of points then 30amp single pole 24vac coil contactor
Jun 04, 2009 | Coleman Mach III Air Conditioner
29 year old Coleman Gas H/A will not shut off... Installed new CT-30 Honeywell 2 wire Thermostat single temp control. The unit works but will not shut off unless I pull fuses & shut off Braker
All coleman gas units is incoperated with a secondary inner stat. It resembles a pie with numbers on its outer edge. Usually silver and the numbers span from 50 to 300 on the top and likewise on the bottom. You must not turn it clockwise. Refer to specifications of manufacture to allow proper function.
Aug 21, 2008 | Coleman Heating & Cooling
I have a 1993 yellowstone camper with a coleman wall thermostat. on the bottom of it- it has a heat/cool switch on one side and the other side has a low-high-fan switch. when we run it on low or high it...
These unit are set up for continuous fan operation when turned on. It does not have an automatic position on your thermostat such as in your house. Set the fan speed to what you are comfortable with and let the thermostat control the temperature.
Jul 21, 2008 | Coleman Heating & Cooling
Unit will not shut off by itself.
A/C only will not shut off would check for low refrigerant charge. If furnace also will not shut off (remember fan will run for short time before shutting down) then either thermostat is wired wrong or control board is defective
Jul 11, 2008 | Heating & Cooling
HAVE A COLEMAN MODEL DRHSO601CB --- THE UNIT WILL RUN FINE FOR SEVERAL HOURS WITH GOOD COOLING AND THEN PERIODICALLY THE TROUBLE LIGHT WILL COME ON THE THERMOSTAT AND THE UNIT HAS SHUT DOWN. TO RESTART -...
You may have a low pressure or high pressure switch tripping out the board as well. You might try cleaning both the indoor (evaporator) coil and the outdoor (condensing) coil. Be sure to turn off the power source before servicing this.
Jun 30, 2008 | Coleman Heating & Cooling
Coleman rv roof air conditioner
(1)Check compressor contactor or relay if it stock in the close position
(2)Check for welded contact points
(3)Check switch control for defect
(4) Check if compressor contactor still geting power when it is off
Let me know what works for you.
Mar 30, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
