SOURCE: My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
SOURCE: washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
SOURCE: very loud washer during spin cycle
it will be your bearings not the belt or pulle you can check this out by having it empty open the door place the palm of your hand on the outside were the top of the door closers to place your fingers ti the inside of the top of inner drum and pull your fingers towards your palm if there is the slightist movement than the bearings need replacing
SOURCE: GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
