Question about Dishwashers
DISHWASHER IS 2 1/2 YEARS OLD AND STOPPED WORKING THE OTHER DAY. THE PANEL LIGHTS ARE ON THE IT JUST WONT GO.
  • Sanchez mum Nov 22, 2008
    Panel lights are all on and flashing but can't get it to set on a chosen cycle nothing happens when I try to choose a cycle, cycle lights just flash on each different cycle and when I press the button to choose it wont select.
  • 3 Answers
Could be the element at bottom of dish washer
Posted on Aug 21, 2008
Kenmore elite dishwasher wont work
Remove the console panel with T15. then remove the cover from the main control board. top right of center of the main control you will see a removable fuse, either a black disc with a black and a black/w white strip connected. remove one wire from the thermal fuse and check for continuity. if it is open replace it. if it is not open call for service.
Apr 30, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a 4 year old Maytag MDBH945AWW and the panel lights come on and I can select cycles... but the dishwasher wont start. I tried holding the start cancel button, tried turning the breaker off for a...
What you need to do is read for continuity and power across the door latch switch. (2 white wires) AND 2 Black wires Both wires must read continuty at the control panel connectors to the power source terminals for the unit to start. Since the control panel lights up I have to assume that the black wire from the door switch has 120VAC on it.
There is also a turbidity sensor that can cause this: http://www.appliancepartspros.com/part_details.aspx?part_id=4114286&image=1
I an not telling you to change parts. You really need to use a meter and follow 120VAC power to find out where it stops when it should be passing through a component.
If you can interpet this diagram....
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1318099&pkw_=basket&model_id=5177084&NewWindow=1
I do not think at this point you need a control panel. It is possible but... the door switch and the thermistor will prevent the unit from starting.
This is ONE source for replacement parts.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177084
There are numerous parts sources on line and locally.
Don't give up on your dishwasher too soon. 4 years is about mid life for your dishwasher.
Thanks for choosing FixYa.
Kelly
Sep 23, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Frigidaire dishwasher had blinking lights then nothing
there is no fuse in the unit but u can unplug and plug into power 2 c if resets.
Aug 18, 2009 | Dishwashers
Diswasher stopped working
There is a thermal fuse on the controller that commonly goes out. If you take apart the panel, and see the computer part, there is usually a part clipped on the side with 2 wires on it. When that goes out, it acts like there is no power to the unit. Very easy and in-exspensive to replace if that's it. It's pretty common on those. Good luck
Feb 15, 2009 | Dishwashers
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
My belling dishwasher wont start, the lights are on but when I press programme the red light no longer skips along the options , it simply doesnt appear.
Hi just trying to solve a similar problem. My machine would turn on but would not fill. It could be that your cold water filter is blocked. If no or reduced water pressure then the machine will not operate correctly. Take off back panel and you should see the filter assembly. GIve this a clean and see what happens.
We have 14 of these dishwashers and so far they have all proven to be very reliable machines. This is the first issue in 4 years.
Paul
Aug 12, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
