Question about HP DeskJet 640c InkJet Printer
Unusual character where special character or underline is given
I have Hp DeskJet 640c printer. I am facing following problems while printing a document.
1) It prints unusual character where special character or underline is given in the document.
For e.g. –
a) In the document I have mentioned a subject and underlined it as follows –
Sub: Estimate for Electric work at Granville Hotel Pvt. Ltd.
Output in printing is as follows –
Sub: Estimate for Electric work at Granville Hotel Pvt. Ltd.PU282,5646PM0PEm▀┐
b) In the document I have mentioned Heading as follows –
Material Specification:
Material SpecificationPU150,5403PM0PEQ▀┐┐‌=R▀┐┐┼;PM2FP
c) In the document I have mentioned –
Telephone:- 4 pair RR cable.
Telephone: - 4 pair RR cable.
2) While printing document it left double margin than the margin set in the page setup.
In page set up I have mentioned Top margin 2”
In printing printer has left 4” margin in the top.
3) It prints a document with double space in between the line.
In the document I have written lines as follows –
1. 20 mm Precision MMS PVC Pipe for slab.
2. 25 mm Precision MMS PVC Pipe for main wiring.
4) It does not print borderlines of the table.
I have created table with border but while printing a document it has printed a document without borderline.
Please guide me to resolve this issue.
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    What have you tried to do to resolve this so far?
    Have you reinstalled the drivers set?
    What type of cable are you using between PC and Printer?
    Have you checked the cable between PC and Printer?
    Have you examined the cable's connection pins for loose ones?
    Thanks,
    Worldvet
  • HP Master
  • 2,794 Answers
If you have a spare USB cable around the house, try that first and see if the cable was bad.
Posted on Aug 21, 2008
SOURCE:
HP Deskjet 640C doesn't print after being long out of use. Cartridges are empty or dry. Is there a way of replacing only the black cartridge for B/W printing by "cheating" the printer? Thx Robert
I found perhaps a couple of cheats when it comes to desktop printers. Their is a RESET BUTTON on the cartage itself that will give you more ink out of your cartage.
Jan 31, 2016 | HP DeskJet 640c InkJet Printer
Problem with hp deskjet 640c printer
i have an hp and find that they (color carts) cannot be refilled- the clever b*st*rds!! they stepped the ink reservoirs so, if you don't insert the re-fill needle 'just right', it bleeds into the others and you end up with a 'muddy' print-out! you need to buy a new hp cart, or shop around for a generic cart (cheaper) google your product & cart #. you may find a source for a cheaper cart.
the black carts. can be re-filled!
good luck!
Oct 08, 2009 | HP DeskJet 882c InkJet Printer
Yellow light keeps on blinking
one of the cartridges is dead and must be changed. buy new one and the problem will be solved.
Aug 02, 2009 | HP DeskJet 640c InkJet Printer
My printer do not print any file
I usually face the following problem while giving printing command to my printer:\r\n
1. On clicking print from file meno the printer does not print and the yellow light upwards starts blinking.
2. Reinstalled the printer after inserted the Printer Software *C6464-10018* v 41 *MacOS 8.1*USB
but printing did not start from this even.
3. sometimes earlier I experienced that only 2-3 lines get printed and after that the upper yellow light again started blinking.
4.Some times the printer goes on sucking papers and prints as the signs of playing cards or some other abnormal shapes lining etc.
Please be kind enough to solve my all such problem and if possible point out step by step action to be taken by me during such an eventuality at a later stage also.
regards: [email protected]
Jun 12, 2009 | HP DeskJet 640c InkJet Printer
Hello Sir i have a problem with hp deskjaet printer. .when print command is given the characters are not printed correctly.
  1. In the printer under Print Quality and Manual Settings, change the Graphics Mode setting from Auto to HP-GL/2.
  2. Use the Enhanced (PCL XL) driver.
Jan 14, 2009 | HP DeskJet 1280 InkJet Printer
HP 640C inkjet Printer
there is not a software or hardware driver download for vista but you can follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&dlc=en&cc=uk&product=58713 and it shows what you can do with the operating system drivers for printers
Dec 11, 2008 | HP DeskJet 640c InkJet Printer
HP Deskjet 640C
Open t cover, behind t catrage u will find a steel rod. Clean t rod with cotton but make sure t cotton or any thing dosn't touch plastic strip which is behind that rod. After cleaning t rod take a cotton bud dipped in machine oil and grease t rod. then close t cover and let t catrage move.
If u have given print command cancle it and restart ur pc. Your printer will work properly. This problem will come again so make sure u keep t rod clean ( clean it once a week or accordind to ur use).
It occurs due to t carbon.
Dec 03, 2007 | HP DeskJet 640c InkJet Printer
HP Deskjet 640c
I am sure that you can go into the properties for the printer setings and choose an appropiate colorseting ..it is probably set to save ink......so u can go to printers in control panel and right click on your printer that shows there and probably just mess with teh setting a little .... another idea is to just delete the printer from there and reinstall it again.......
Apr 25, 2007 | HP DeskJet 640c InkJet Printer
HP DeskJet 640c InkJet Printer Logo
163 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
