Question about Acer Aspire 5610-4648 Notebook
I want to install Windows XP on my VIAO laptop with Vista preloaded?
I have Vista preloaded on my VIAO laptop. How can I install Windows 2008 in any other drive.
  • 1 more comment
  • sarikarathor Aug 21, 2008
    thanks.
    I have already a partition . C drive has 40 GB. and G drive is 20 Gb....Do i need another partition yet? Cant I install Windows XP in G drive? Please assist me with the whole procedure...
  • 2,794 Answers
If you want both operting systems on your drive, go to control panel. Select administrative tools. Select computer management.
Select storage
Select disk management.
This is the area where you can create a partition to an existing hard drive. Mave sure there is plenty of available space on your C drive to create another partition
Posted on Aug 21, 2008
  • Tim Babcock
    Tim Babcock Aug 21, 2008
    Using the Windows interface
    1. Open Computer Management (Local).
    2. In the console tree, click Disk Management.
      Where?
      • Computer Management (Local)
      • Storage
      • Disk Management
    3. Right-click an unallocated region of a basic disk, and then click New Partition, or right-click free space in an extended partition, and then click New Logical Drive.
    4. In the New Partition Wizard, click Next, click Primary partition, Extended partition, or Logical drive, and then follow the instructions on your screen.
    Notes
    • To open Computer Management, click Start, and then click Control Panel. Click Performance and Maintenance, click Administrative Tools, and then double-click Computer Management.
    • You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure.
    • You can create primary partitions, extended partitions, and logical drives only on basic disks. You should create basic volumes instead of dynamic volumes if this computer also runs MS-DOS, Windows 95, Windows 98, Windows Millennium Edition, Windows NT 4.0, or Windows XP Home Edition.
    • On a master boot record (MBR) disk, you can create up to four primary partitions, or three primary partitions and one extended partition.
    • On a GUID partition table (GPT) disk, you can create up to 128 primary partitions.
    Using a command line
    1. Open Command Prompt.
    2. Type:
      diskpart
    3. At the DISKPART prompt, type:
      list disk
      Make note of the disk number of the disk on which you want to create a primary or extended partition.
    4. At the DISKPART prompt, type:
      select disk n
      Select the disk n where you want to create the primary or extended partition.
    5. At the DISKPART prompt, type one of the following:
      create partition primary [size=n] [offset=n] [ID=byte | GUID] [noerr]
      or
      create partition extended [size=n] [offset=n] [noerr]
      or
      create partition logical [size=n] [offset=n] [noerr]
    Caution
    • Creating partitions with this parameter might cause your computer to crash or be unable to start up. Unless you are an OEM or an IT professional experienced with GPT disks, do not create partitions on GPT disks using the ID=byte | GUID parameter. Instead, always use the create partition efi command to create EFI System partitions, the create partition msr command to create Microsoft Reserved partitions, and the create partition primary command (without the ID=byte | GUID parameter) to create primary partitions on GPT disks.
    For MBR disks, you can specify a partition type byte for the partition. If no partition type byte is specified on an MBR disk, the create partition primary command creates a partition of type 0x6. Any partition type byte can be specified with the ID=byte | GUID parameter. DiskPart does not check the partition type byte for validity, nor does it perform any other checking of the ID parameter.
    For GPT disks you can specify a partition type GUID for the partition you want to create:
    • EFI System partition: c12a7328-f81f-11d2-ba4b-00a0c93ec93b
    • Microsoft reserved partition: e3c9e316-0b5c-4db8-817d-f92df00215ae
    • MSDATA partition: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
    • LDM Metadata partition on a dynamic disk: 5808c8aa-7e8f-42e0-85d2-e1e90434cfb3
    • LDM Data partition on a dynamic disk: af9b60a0-1431-4f62-bc68-3311714a69ad
    If no partition type GUID is specified, the create partition primary command creates an MSDATA partition. Any partition type can be specified with the ID=byte | GUID parameter. DiskPart does not check the partition GUID for validity, nor does it perform any other checking of the ID parameter.
    For scripting only. When an error is encountered, specifies that DiskPart continues to process commands as if the error did not occur. Without the noerr parameter, an error causes DiskPart to exit with an error code.
    • To open a command prompt, click Start, point to All Programs, point to Accessories, and then click Command Prompt.
    • You cannot create partitions on removable media using DiskPart.
    • For more information about DiskPart, click Related Topics.
  • Tim Babcock
    You will need another partition to install Windows XP. G drive is used to restore Vista.
I have a hp pavillion dv6604cl laptop that came preloaded with vista. I'm trying to install windows xp professional sp3. what driver do I need, so my windows xp install will work.
to install xp ,just insert the disk with sp3 pack it will automatically ask whether to install.there after follow the options .if u want to partion the system with two os do the necessary setings
Aug 28, 2010 | Computers & Internet
To istall xp on vista preloaded laptop
go on to the hp main site and search for your drivers i m sure you will get all of them
Aug 02, 2009 | Computers & Internet
Tweak BIOS to install Windows XP
Shouldn't need any "tweaking". Not sure offhand on the c700, but manytimes the Compaq bios is limited (and I'm a Compaq user - servers, desktops & laptops). What is itexactly that you're trying to achieve? I replaced Vista on my F500 series first with XP and finally with Linux - no problems (other than initially finding drivers). Just make sure to download and build an XP driver disk beforehand and you won't have any problems.
Jun 30, 2009 | Compaq Presario 700 470024-192 Notebook
"Windows vista booting corrupt"
try to boot ur laptop with disc manager cd or win XP.
if doesnt works then try win 98 cd and delete ur C:/ partiton and install new vista
Apr 18, 2009 | Lenovo 3000 N500 Notebook
How to install windows xp on preloaded vista
If you have Windows XP OS installation CD, just put it in and boot your computer.
Leave the system till it comes to a blue screen. Choose to install a new OS and follow teh on-screen instructions.
Choose to format the C drive if you wish to delete Vista and the data in you C drive. Proceed with the instructions and you will be able to install the OS.
Hope this helps!
Mar 29, 2009 | Microsoft Windows XP Professional With...
Installation of windows xp on a preloaded windows vista laptop
See this , you have to download the SATA driver , as you have a SATA hard disk , then slipstream it into the xp installation package.
Alternatively , put the driver on a floppy and press F2 when prompted during the setup when its loading all the files (It says Press F2 if you want t o install a SATA Driver"
Then it will detect your drive and install as normal :D
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Jan 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
Xp driver
Get It Here http://videoxdrivers.net/2008/02/19/request-download-acer-aspire-5710-driver-for-windows-xp/
Jul 07, 2008 | Acer Computers & Internet
Presario f700 drivers
You have to download XP drivers from the manufacturer's website. This normally happens because your harware was designed for the new OS(Vista).
Just go to hp.com and search for the model of your Laptop.
May 20, 2008 | Compaq Presario 700 470024-192 Notebook
Installing Photo Explosion Softwear
its because of your os
most of all this software is working good in win xp so kindly try to install that software in windows xp because still windows vista is having some issues with some less popular softwares
so try it on windows xp or findout way to run it on windows vista (find windows vista version of your software)
Mar 26, 2008 | Computers & Internet
Windows operating system
you can make a dual book (multi OS) on your laptop so that you can just switch over to XP or vista and vice versa.
try this article on MS on how to install a multi OS. i haven't tested it in vista though...but i think it would work..please let me know.
also..you can use a Virtual PC and install XP there, its much more easier.
Oct 30, 2007 | HP Pavilion dv4000 Notebook
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
