Question about Sony Cyber-shot DSC-W70 Digital Camera
Video sound when i try to record on video mode, it will record but with no sound. the sound in the back sounds very scratchy but you can't hear anyone.
  • Anonymous Sep 09, 2008
    MY CAMERA WILL PLAY VIDEO BUT NO SOUND.
  • Sony Master
  • 2,794 Answers
Could be a mic on your camera. Is there anyway to change the mic setting in the control panel of the camera? If not you could have a bad mic or that could be how the mic was designed by Sony.
Posted on Aug 21, 2008
Scratchy sound on turntable with mat om
One of two things. The deck has got a static problem. Perhaps caused by an earth connection problem.
Or you have a bad earth connection on the cartridge.
Dec 27, 2015 | Crosley Executive Portable USB Turntable
SCRATCHY SOUND
This could be a fault with the built-in microphone.
One thing to try before condemning the camera is to plug in an external microphone and see if the noise disappears.
Good luck
Oct 19, 2007 | JVC GR D370US camcorder Mini DV
Can't hear audio on video playback (neither direct from camera nor from pc)
This is because the camera is not capable to record the sound. The camera was not designed with any audio speakers to be able to record and playback sound recorded during movie mode.
Apr 17, 2009 | Olympus FE-25 Digital Camera
Speakers sound tinny
Did it ever work right? When did the problem start?
Echoes:
There are many DSP modes with this unit. Echoing voices is probably one of them. This is a user setting. Look at the front panel for information regarding that. I imagine the Straight/Effect button might change it.
Have you read the manual and followed the specific menus for setting up the DSP modes?
Screeching, Scratchy Sound: I don't think this is related.
Did it ever work right? When did this problem start?
Is it from all sources? All channels? All DSP modes?
I need more to information be helpful.
Mar 21, 2009 | Yamaha HTR-5930 Receiver
I don't hear any sound when I record on my vivicam 3710, can you please tell me what I need to do to hear sound when I play the clip back on my computer?
Sorry, but the ViviCam 3710 does not record any sound when in video mode. You can add a soundtrack using video-editing software on a computer, but you cannot record one on the camera.
Jan 06, 2009 | Vivitar ViviCam 3710 Digital Camera
Audio meltdown!!
Use a head cleaner tape (available on eBay most likely) and clean the recording heads.
Mar 14, 2017 | JVC GRD650US DIGTL VIDCAM 32X ZOOM 16:9...
No sound when playing back video
I had the same problem. Try this: open the LCD screen so that you can access the playback buttons.Make sure camera is in playback mode. Press the "menu" button. Select "narration" . Switch narration to "off" .Now you should hear the recorded audio when your tape is playing.
Jan 03, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Sound scratchy
Seems to me that the first thing you want to do is find out if your problem comes from the camera speakers/output, or if it records them scratchy. Take one of the "scratchy" cassettes, and play them on another device to see if it transfers bad audio. If it does, then you're worst off offcourse, more of a repair. If it doesn't you can decide you don't need a repair, as long as it does the job. Good luck
Apr 01, 2006 | Panasonic NV-DS60 Mini DV Digital...
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Sony Cyber-shot DSC-W70 Digital Camera Logo
105 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
