Question about Zenith XBR716
Unable to record from tv
I have a Zenith ZBR716 and I'm trying to record off the tv. The RCA tv only has AV input and coaxial IN for cable/ant - to watch tv I have to have the tv tuned to local channel (7-9-13) I use the AV cords to plug from the tv AV IN to the recorders AV In (bottom set) just like the manual tells me to. But to watch anything off the DVD/VCR I have to have the TV turned to VID (who/input has VID, FRT and channel selections)
any ideas? I had another dvd recorder combo that also had a cable/ant coaxiel connection and I could connect thru that but I don't see any option on this one.
I have the same problem and I called Zenith for support. I was told that the ZBR716 does NOT have a "tuner", so the only way you can record what is on TV is if, and only if, the TV has OUTPUTS (3 connectors), which could be connected to the ZBR716's inputs. But then you could only record what is currently being watched on TV. You could not record and watch something else, or set up to record something at a particular time on a particular channel, because the TV has to be on.
Unfortunately, I didn't look into this until some time after I bought the unit, so I can't return it. I was told to get a VCR/DVD recorder WITH a tuner.
I, too, had a VCR with a separate coax connection for the incoming cable tv,and it worked like your other one did.
My fault for not looking into it sooner, Circuit City's fault for selling me something when I was very specific about what I wanted and what I wanted to do with it.
you can call zenith yourself, go to www.zenith.com and hit the support page and eventually you'll find the phone number.
good luck.
Posted on Oct 08, 2008
I am trying to connect a DVD player to a RCA F25216BC 25" TV - the TV only has an F type Coax connector and does not have a CH 3 or 4 switch - I put the input from the wall to the DVD player and out to the...
Your TV must be equipped with AV inputs (RCA jacks - yellow, white, red)
in order to connect this unit. If your TV does not have AV inputs, you will need a RF Modulator to connect the DVD recorder to your TV's
antenna/cable input. RF Modulators are available at
major electronics retailers such as Radio Shack or Wal-Mart and allow the 3 RCA outs from the recorder to connect to the RF modulator RCA inputs and then you can connect a coaxial cable from the modulator to the TV RF input and select channel 3 or 4 on the TV. The DVD recorder will not pass thru signals to the TV using coaxial cable as far as DVD are concerned.
Aug 22, 2010 | RCA F25216BC 25" TV
Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
Jul 22, 2010 | Sharp 27N-S300 TV
Just need to know how to hook up to tv to get sound
If you don't have a cable box or satellite receiver, you will use the "Audio Out" or "Monitor Out" from the TV to any audio input on the receiver. It's just a standard RCA cable or if you have an "Optical input" on the receiver, use that. If you are using a cable box or sat, the audio would come from the cable/sat receiver by standard RCA, Optical, or Digital Coaxial, whichever your AV receiver will support. Hope this helps. If you need further help, post a comment and I can walk you thru it.
Sep 27, 2009 | Zenith ZHD-311 300W Complete Home Theater...
Cannot connect zenith vcr to zenith tv thru cable box
Hello mcgillicu390,
From your VCR you should have an (RF OUT) and an (RF IN) Connector (these also might be marked as ANT IN and ANT OUT, or CABLE IN and CABLE OUT).
The same goes for your TV (RF IN), (ANT IN) or (CABLE IN).
Now, take your Coaxial Cable (Cable with screw on or Push on connector with a wire in the center of it) and connect it to the TV (RF IN), take the other end of the same cable and connect it to the VCR (RF OUT).
Then connect your cable TV set top box or antenna to the (RF IN) of the VCR.
If you are using a cable box set your VCR and TV to Channel 3 or 4 (depending on your area)
If you are just using the VCR and an antenna set your TV to channel 3 or (depending on your area).
That should do it for coaxial connectivity.
If you are using the composite video and Audio cables to connect to your TV here are the directions for that.
Looking at the back of your TV you will see Three RCA type connectors colored as Yellow, White, and Red. Yellow is Video, White is your Left Audio, and Red is your Right Audio. They should be marked as (Video IN), (R Audio IN), and (L Audio IN). *note these markings may not be exactly like what is written, however the indicators should be close to what you are seeing.
Now look at your VCR, you may see a lot of RCA Connectors (up to 6 of these connectors) don't worry, you are only looking for the ones that say (Video OUT) (R Audio OUT), and (L Audio OUT).
Once you find the connectors on both pieces of equipment, take the Yellow, Red, and White tipped cables and plug the in their respective jacks Yellow tipped cable connects VCR (Video OUT) to TV(Video IN). Red tipped cable connects VCR (R Audio OUT) to TV (R Audio IN), and finally White tipped cable connects VCR (L Audio OUT) to TV (L Audio IN),
Once the cables are connected you will be able to use the composite selection on your remote to view the images from your VCR, the VCR in this case will be acting as the tuner for your TV with out you having to set the TV to channel 3 or 4, you will just have to use the AUX or whatever setting on you remote that allows the composite video to display.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 27, 2009 | Zenith B27A11Z 27" TV
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
Sep 27, 2008 | Televison & Video
Zenith 716
THIS RECORDER DOES NOT HAVE A TUNER BUILT-IN. YOU MUST RUN IT FROM "AV" INPUTS INSTEAD.
Sep 22, 2008 | Zenith XBR716
Unable to connect philips dvd recorder/vcr recorder to philips flat screen 19pfl4322 tv. HAVE AV 1 AND AV2 ON FLAT SCREEN TV BUT RECORDER WILL NOT GIVE MENU PICTURE. COAXIAL CABLE ATTACHED TO VCR AHD...
make sure that av 1 out on the dvd go into av1 in on the screen and av2out goes to av2in onto the screen.make sure the cable is not loose.press av on the tv remote till you find it. same with the vcr remote
Mar 31, 2008 | Televison & Video
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Hook up
connect yellow white and red cables FROM AUDIO/VIDEO out from the dvd player to the tv. connect your cable wire or coaxial cable to this unit. (the first one is going to be on your tv disconnect that one and put it on this unit where it says ANT IN.) connect the cable that came with it on ANT OUT or a cable that you might have and then turn on tv. and use your original remote to your television and look for a button that is regarding input or tv/video or tv/av. This function will only be on your tv remote. NOT DIRECT TV.
Dec 29, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Zenith XBR716 Logo
148 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
