Question about D-Link DI 514 Wireless Router (DI-514)
Very slow connection speed
Getting 10 mgps from modem with computer hooked up with ethernet , but barely get 1mgps when wireless. tech said i need a new wireless router.??
  • D-Link Master
  • 6,487 Answers
You just need to update the firmware of your router, firmware is the software inside the router that make it function so since you have a speed problem a new firmware should fix that...
Posted on Nov 07, 2008
Why does my internet keep dropping?
change your connection system
you can get TP link units that plug into the house electrical system and run ethernet cables from the computers on a home network system
works like a charm over any distance on the same power circuit for the house
may be a wireless dongle will fix your problem
Apr 11, 2017 | Motorola Computers & Internet
I have 6mbps speed but my speed get too slow on my modem. so how can i improve my speed.
is that a phone modem
this are conventional speeds expected:
  • Conventional Ethernet can transmit data at rates from 10 Mbps up to 100 Mbps.
  • Phoneline networking specification, HomePNA 2.0, transmits data at rates up to 10 Mbps.
  • One type of powerline networking technology promises data speeds up to 189 Mbps.
  • Wireless Ethernet has data transmission rates up to 11 Mbps.
  • HomeRF goes up to 1.6 Mbps.
  • Bluetooth goes up to 3 Mbps.
the speeds noted above are theoretical as other factors WILL affect your connection speed and WILL LIKELY lower the connection speed between your device and the ISP.
for comparison check on and compare other isp, changing isp is your more concret solution.
Nov 22, 2009 | 2wire Computers & Internet
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Trouble with paradyne or linksys
Just saw your post, so please accept my apologies for being almost a month late in responding, as I only joined this service on March 26th.
1. When a modem has both usb and ethernet, only ONE of the two should be used as most isp modems will allow one or the other.
2. Your Vonage should be discreet and not intermingled with the rest of your system. It would be better to connect the Vonage to a router, and not the router to the Vonage. iow, do not connect the Vonage modem between the isp's modem and your router.
3. denigration of service or slowdown is typical with VOIP if more than 2 systems whether telephone or other systems are connected, due to the ringer voltage splitting that occurs when you put more units on the Vonage, or any other Voip modem. One ISP solves this by providing separate outputs for Voip and Ethernet.
Observation of these rules should speed up your system.
Mar 01, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
Cannot connect 2nd computer
you can always give it a static ip...if you need to know how to do this repost here..
Jan 26, 2009 | Dynex 5 Port 10/100 Ethernet Switch...
Wireless router problems
Hi Andrew i had the same prob all i did was to connect by hard wire 1st. Connect your modem ethernet cable to your router , then connect your router to your computer again with ethernet cable, When i did this nothing happend at 1st so i unplugged the modem (not router) leave for about 20 sec's then plug in your modem within about 10 secs i was up and running. I hope this helps
Dec 31, 2008 | Belkin (F5D7230-4) Router (587009)
USB Connection
Hi floinmist .
Westell 6100 modem by default can only be used for 1 PC . It cannot orit is not enabled to use for 2or morer computers as it creates a conflict within. Ethernet connection is the BEST connection for you to use.> your USB is sent to you by you provider { ISP} or by westell packages. Its is only a spare cable just in case your PC doesnt support ethernet connection ,  nothing else.
To resolve this issue you might want to upgrade your modem to a router w/c is westell versalink . You can connect 2 or more computers  { wired or wireless connection } and is more stable compared to your westell 6100.
Connecting 2 computers could cause slow, intermittent and NO connections at all problems.
IF you have other questions pls feel free to ask and let me know if theres anything ii can assist you with .
Best wishes.
May 02, 2008 | Westell Wirespeed LiteLine 6100...
Desktop has very poor/slow connection through wireless router
This sounds like a spyware/virus problem. Try running the computer in safe mode(With networking) and see if it's any faster. You should also run your Anti-spyware,AV apps to check for problems.
Sep 13, 2007 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI 514 Wireless Router (DI-514) Logo
64 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
