Question about Texas Instruments TI-89 Calculator
Is answering in fractions, and I'd like decimals.
I would like my answers displayed in decimals instead of fractions, can I switch between the two?
  • olsonrm Feb 21, 2009
    How can I easily change my TI decimal places to read 2 instead of 14? and undo it.
    Also how can I get my answer to show % instead of dec. Hopefully easy like the diamond key and enter sol.
    olsonrm@sbcglobal.net
    thanks!
  • 6 Answers
What you do is click on the 'mode' button and go down to the 'Exact/Approximate' parameter and choose Approximate. hit enter and you're good.
Posted on Sep 20, 2008
  • 38 Answers
I don't know about a permanent solution but you can get it to give you decimals with a second keystroke. just hit the diamond key and enter and that will get the calculator to approximate the fraction for you.
Posted on Aug 27, 2008
SOURCE: fraction problem
follow the following sequence of steps
mode>exact/approx and then select approx
Posted on Jun 17, 2008
  • 7993 Answers
SOURCE: I cannot find how to change my answer display to a...
If the result is already calculated and displayed, press the [S<=>D] key It will convert a fraction or radical to decimal. This is always possible. If the result is decimal it may be converted to a fraction or a radical (Not always possible).
If the expression to be evaluated is still in the command line and you have not pressed the [=] key, you can force the result to be displayed in decimal format by pressing [SHIFT][=] instead of just [=].
More permanently. If you do n o care for fractions and radicals, set the Input/Outpout mode to LineIO. To do do press [SHIFT][MODE] to access the (SETUP) screen and select [2:LineIO]
Posted on May 25, 2010
  • 19 Answers
SOURCE: Cannot figure out how to display answer as a
Press the S<>D button to convert from decimal to fractions.
Posted on Jun 30, 2010
  • 102366 Answers
SOURCE: how to have casio 115ES display answers as
To convert a single value, press the S<>D key. To have all answers appear as decimals, press 2nd MODE 2 to select LineIO mode.
Posted on Aug 19, 2010
  • 7993 Answers
SOURCE: I am trying to change
Press [SHIFT][MODE] to enter (SetUp).
Select option [2:LineIO]
All results will be displayed as decimal numbers.
Posted on Jan 15, 2011
I need to know how to change a decimal answer to a fraction answer
Press the S<-->D button to switch between decimal and fraction displays. Bear in mind that the calculator can not display all numbers as fractions.
Sep 03, 2013 | Casio fx-300ES Calculator
How can i change my calculator so the answer will be in decimals instead of exponents or fraction?
There is a misconception hiding here in your statement. A decimal result on a calculator is often no more than an approximation: Try expressing 1/3 as a finite decimal representation. So, the only exact results that you may get are those displayed as fractions and those with radicals.
Now let us address your question. The calculator has a limited display capability. Any decimal result that is too small or too large to fit in the display window will automatically be displayed in scientific notation (the one with exponents).
If you want exact results, you should set the Input/output to MathIO. Even then, if the expression requires more display space than is available, it will be displayed as a decimal number.
Sep 12, 2012 | Casio fx-300ES Calculator
My new casio fx-300ES calculator outputs answers as a fraction... how can i change the output to a decimal point?
To change a displayed result into a fraction, press the [S=D] key.
To force a result to be displayed as a decimal number before it is displayed, press [SHIF][=] instead of [=].
Aug 15, 2011 | Casio fx-300ES Calculator
My calculator will show fractions instead of decimals when doing division. How do I change that? There is a N1 displayed in the lower left corner also...I think that may be the problem
Getting Decimal Answers by Disabling WriteViewelw516.gif on the Sharp EL-W516 Calculator
The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors.
At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers.
If you prefer to always get decimal results you need to disable the WriteView display mode. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.
Disabling WriteView
Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.
There are now two options: 0: W-VIEW, and 1: LINE
Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.
To return to the WriteView display, go through the steps above but press 0 for W-VIEW.
NOTE: It is not possible to have decimals as the default answer form when in WriteView mode.
Feb 07, 2011 | Sharp ELW516 Scientific Calculator
How do i convert fraction answers to decimals?
If result displayed is to be converted, press the S-D key. This will toggle display from decimal to fraction and from fraction to decimal.
To force a result to be in decimal format press SHIFT = instead of just =.
To configure calculator to display only decimals, press the SHIFT MODE key sequence to enter SETUP and seledct 2:LineIO.
Oct 14, 2010 | Casio fx-300ES Calculator
I can't get the answer to display in decimals only fractions.
For converting answers in decimal to fraction or fraction to decimal there is a S<->D key above delete key.If the answers is in fractional form press this key and it will be converted to decimal form.
Jun 04, 2010 | Casio FX-115ES Scientific Calculator
I cannot find how to change my answer display to a decimal instead of a fraction on a Casio FX-115ES. I am working with financial formulas and need decimals! Anyone???
May 20, 2010 | Casio FX-115ES Scientific Calculator
When dividing the display outputs the answer in fractions but I want the default to display in decimal
May 20, 2010 | Casio fx-300ES Calculator
How do i display a fraction?
Press [SHIFT][MODE][1:MathIO].
When in MathIO, you can obtain decimal results if you press [SHIFT][=] instead of just [=] to calculate.
Also, you can use the [S<=>D] key to toggle from one display format to the other ( Fraction <-> Decimals) or (Radicals<->Decimals).
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Texas Instruments TI-89 Calculator Logo
385 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
