Washer won't drain or spin out the water
My Whirlpool Washer LXR7244JQ1 it will fill up, agitate and wash but wont drain or spin the water out. (it doesn't leak).
  • 9 more comments
  • Anonymous Nov 23, 2008
    my fridgedaire FTF530ES1 WASHER WON'T SPIN OR DRAIN THE WATER OUT, IT DOESN'T LEAK THO..... WHAT DO I DO?
  • Anonymous Nov 24, 2008
    My Whirlpool washer won't drain or spin out water. There is no water leaking out and the washer blades work. For Spin cyle/Water Draining, we get no movement.
  • Anonymous Dec 09, 2008
    won't drain but seems to work fine otherwise
  • Anonymous Dec 26, 2008
    my maytag wont spin or drain the water
  • Anonymous Jan 02, 2009
  • Ray Gautam Jan 12, 2009
    My Inglis washer won't drain out and the spin cycle also don't work
  • cdtravis1965 Jan 21, 2009
    front loader that want spin and the water want drain. it makes a humming sound
  • sambo4564 Feb 24, 2009
    my washer just washes clothes through the whole cycle wont drain or spin dry
  • Anonymous Apr 06, 2009
    machine will occasionally make a humming noise but will not drain, spin, or complete cycle. It worked last night had no problem but this morning it will fill up with water and do nothing else but humm. The humming doesnt only happens when i try to do the spin cycle and does not do it everytime i try, just when it wants to pretty much, and it is also leaking from bottom of washer i do not know what to do. My fiancee is over seas and i am a trry and fix it yourself typ of person but i know nothing about washers, please help!
  • Whosyomamma Apr 06, 2009
    My Bosch front loader agitates, but will not spin, drain, or complete a load. Error E:04 on panel. I have read solutions where something is stuck in the pump, so went in through the front panel, loosed a flood of water from behind the screw cap, but nothing was stuck in the works. I went so far as to replace the pump, but still it will not spin or drain with brad new part. I would think it could be the belt, however the machine DOES agitate through the first part of the cycle. It was suggested that perhaps the signal to begin the spin cycle is not being transmitted properly to the parts that need to get it, so perhaps a wire somewhere needs to be replaced. This is beyond my scope of knowledge. There is water leaking out from tears in the rubber seal on the inside of the machine and this may come to bear on the problem, I don't know. What I do know is that this expensive machine isn't working, I have dirty clothes from myself and two young kids piling up, and the manual is woefully devoid of troubleshooting tips.
  • Anonymous May 05, 2009
    Whirlpool washer will wash and agitate just fine but then will not go into spin, drain or rinse cycle. It just stops with water full
I pulled the motor out od the bottom and pulled a baby sock out of the gear in the balis tank
Posted on Apr 19, 2011
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
4,378 people viewed this question
Top Washing Machines Experts
