Question about Kenwood KVT-715DVD Car DVD Player
Green wire hookup?
Does the green wire have to be hooked up for the unit to work?
No it does not have to be hooked up but if u want the dvd to come on you have to hook it up to ground wire.
Posted on Sep 25, 2008
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
Have a maytag dryer with no directions. My cord has black, red, white and green wires - the green was screwed to the outside of the old dryer. This dryer has blue, red, and a white with green - the green...
Hi lasanaritchi...
The blue and red will be your two 110 volt lines (2 X 110 volts equals 220 volt) and the white one will be the neutral, green wire will be ground
Go to this link and see a picture of how to hook up your dryeer cord...
Please take time to rate me.
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Jul 24, 2011 | Dryers
Hello, i am trying to hook up my xbox 360 to my
Make sure the tv is set to A/V 1 if it has multiple A/V hookups make sure the tv is on and set to the A/V channel you are trying to use. And make sure your cable is set to tv if you have a composite cable. If that does not work try buying a composite cable (thats the yellow red red blue green white cable). If that does not work. There might be something wrong with the xbox or tv.
Jun 26, 2010 | Video Game Consoles & Games
My Maytag MEDC400VWO dryer needs the 4 wire instead of 3 wire hookup. I have it, but not the manual. How do I hookup the 4-wire and in what order onto a 3-wire dryer?
red and black wires go to terminals marked L1 and L2 hook these up either way its not critical, then white is the neutral and goes to the N terminal then green is the safety ground and it should be connected to a terminal that attaches to the units frame
Sep 17, 2009 | Dryers
Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
Apr 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
Jan 26, 2009 | Clarion DXZ545MP CD Player
4 prong to 3 prong
connect green wire back to cabinet rear at green screw..in a 4 wire hookup the green wire from the dryer was supposed to be either cut off or attached back to neutral(center screw)
Oct 24, 2008 | Roper REX4634KQ Electric Dryer
Replacing thermostat
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Thermostat hookup
There will be none commercially available. You need to use the diagram that came with the thermostat and the diagram on the access panel of the furnace. Typically Red goes to R, Green goes to G and so forth. Red and White are your heat cycle wires. Red and Yellow are your cooling and the Green is to operate the blower. If only 4 wires, you need a jumper at the thermostat going from R1 to R2. Check the connections at the furnace to make sure they are attached the typical way prior to attaching them to the thermostat.
Nov 26, 2007 | Weather King 12AJA6001AH Air Conditioner
Kenwood KVT-715DVD Car DVD Player Logo
125 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
