Central air is not cooling this evening. We shut the system off for a couple of hours to make sure if it was not frozen up. I have taken the cover off the thermostat ..there are two vials inside---should I be looking for the bubbles on the top and bottom to be level? Unit is 10 years old.
  • murphyme Aug 21, 2008
    Will take a look at this when I get home this evening. Wow! That would be great! Someone at work told me the "compressor might be grounded" any idea what the heck that means and is that a problem or just a fact. Thanks..
    Problem Solver:
  • 9 Answers
Neither. Your problem is simple. If you look inside your unit which is located outside. The compressor. There should be a silver, oval in shape, part usually affixed to the wall of the unit. This device, if swollen or mishapen, thats your culprit. Replacement cost is approximately $15.00. The only other problem you may have without looking at the unit is. It may have a serious leak that have allowed all freon to escape. If there are no freon your unit will not freeze up.
Posted on Aug 21, 2008
  • fosterb9 Aug 27, 2008
    Inside the unit the compressor is located. A large black cylinder. On the side of the compressor is a black box with wires going inside of it. Usually there are three wires. If one of these connections works loose (which is rare) your unit will react similiar to your original problems described. The important word is similiar. "Compressor is grounded" ???? That terminology has not been used in my field of interest as something derogatory. Beats me what they are trying to convey.
My hotel room ac is blowing cold air just not strong enough to cool entire room
It may be frozen over. At the front of the unit there should be an air filter. May be behind a panel that opens, or it may slide out. Behind that filter will be the indoor coil or evaporator coil. Look to see that coil and if there is any ice on it. It will be a white ice covering the coil. If it's frozen up, turn the cooling mode to off, turn the fan mode to on, and let it run at least a couple of hours to thaw. Let maint. know it's frozen up and needs service. Get what you pay for! If it's not frozen up, find some way to check the supply air temp. Some sort of a thermometer. It should have a 50-60°f supply air temp, depending on the indoor temp. Most I've seen will supply 45°f, but 50-60 is a good reference. Hope this helps! I bet it's frozen up.
Apr 06, 2017 | Heating & Cooling
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
We have bought a home with the wite rodgers thermostat 1f85-275 it doesn't seem to be working. on the top right of the screen it states 1&2 stages? anyway, help would be appriciated
Hi, this thermostat is for central heat and air systems that have more then 1 stage of heating or cooling. For example, your unit may have 2 stages of cooling, as in 2 compressors, or 1 stage of cooling and 2 stages of heating as used in commercial heat pumps. This is a multi-stage heat pump thermostat. It may be just a matter of programming the stat. If you can find a manual on it, this would help. If you open the cover, it should have directions on how to program it.Make sure you have power to everything, check all breakers to see if they may be shut of, even if you have a display, doesn't mean you have high voltage to run the unit. Make sure fan is in auto, and on heat or cool, and temperature set for it to come on. Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating Contractor
PS Your unit has 1 stage of cooling, and 2 stages of heating.
Nov 05, 2010 | Heating & Cooling
Not cooling proberly. Unpluged unit for 5
return air ducts are frozen and need to be defrosted. unplug unit and with doors open , introduce warm air from a blowdryer for a couple of hours , the ducts that are frozen are behind the rear panel on the rear wall of the freezer
Oct 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Condenser shuts down after a couple of hours.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
Aug 19, 2009 | Amana Haier AP125HD Air Conditioner
Central air/heat pump not putting out cold air
I have some things for you to check. If you look at the outside unit the lines going into the house. Are they frozen? Have you had any yard work done, the reason I ask is they could have accidentally cut or pulled out the thermostat wires to the ac unit. Also, inside check for the same thing, frozen lines. Also, you may want to check the drain coming from the inside unit, it may be clogged.
Jun 22, 2009 | Heating & Cooling
Neither Roof Air Works
Yes and no .. Freezing temps should not affect your A/C at all ... BUT .. there is a freeze control box, its called a control unit to prevent itself from freezing up and burning out, take down the lower cover and you will see it. Your problem is more likely to be more central since neither are working Thermostat or even the control box's in genera, even could be a freon problem if the cold weather was really bad and you could have a leak on your lines, check it out and see what you got!
Dec 31, 2008 | Dometic Rooftop RV Air Conditioner
Toshiba P30/P35 Power keeps shutting down
An overheating occured on the unit that why it's shut off when the high limit of temp. reaches.
Try to use a lap cooler, it may reduce an overheating to the unit,
Mar 06, 2008 | Toshiba Satellite P30 P35 Series Notebook
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
