The reason the pump will lose prime anytime is because insted of the pump pulling in water, it is now pulling in air from some source. When you set up the pool to be vacuumed, you must be sure to prime the vacuum hose with water before inserting the vacuum hose into your suction. The easiest way to do this is to:
1. attach vac.head unto the vac.pole and 1 end of the vac hose.
2. holding on the the other end of the vac. hose so it doesn't get away from you. slowly lower the the set up into the pool and make sure the pole doesn't get away from you either.
3. now you will notice part of the hose is filled water and part of it is floating ontop of the water with air still in it. Now while sitting on the edge of the pool, pull the hose toward you to where you think the part of it is now full of water. than slowly feed the rest of the hose, hand over hand until the end of the hose and you will see water come out the end, the hose is now totally full of water.
4. This is the tricky part, cuff your hand over the end of the filled hose and with the pump running plug the end into the suction, re: skimmer or suction port.
At this point you might have induced some air into the system and the pump may lose prime or start to lose prime. Go over to the pool equipment and if present, bleed the air out of the filter.
Hope this solves your problem.
