Mother Board does not see BDRom can not format ard drive changed BD Rom and MotherBoard
As you see the list of what I have And a few other thing of course, but it does not work. The hard drives are empty and the MOBO does not all ways see the bd-rom,Orginally I figured it was a bad drive so I took it back to CompUSA and the computer they tried it and it worked I thought wow, They tried it two more times and it worked then it did not ok change the drive, But still the problem is the there and it comes up check cable check power Ok brand new PSU but we checked it and found an intermitt problem so we changed it and instead of it not seeing it every third time it see's it every third time. So, now we are thinking there is something wrong with the SATA ports on the MOBO so we change the motherboard and now it only sees the bdrom once in a while aany idea's? Email: wcadwalader@hotmail.com
  • 2 more comments
  • terrbo Aug 21, 2008
    It's an XFX 8200 w/ AMD 5200+ CPU
    4GHz OCZ 2 sticks PC6400 PSU 550 Corsair
    Goldenorb II Fan
    Sony Blu Ray BD-Rom
    Yes, One is a slave and one is a master wish it was that simple
    also tries taken out one of the memory cards so, that I am just running just one and then switching them around to see if maybe a bad memory stick and no change.
    And I have even tried to run with just a single master hrd drive again no cahnge.anybody with any ideas
  • 3,051 Answers
Do u have one as a slave and one as a master and is bios set up that way too
Posted on Aug 21, 2008
HP 8X BD-ROM/DVD Writer Combo not reconized by windows XP
make sure that the bd -rom/dvd combo is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 14, 2011 | Philips HP BD240I Blu Ray Combo Drive ...
Notebook turns off when BDROM connected
try to cheak ur BDROM with other laptop.if the same problem is occured then the problem with ur BDROM.
Apr 22, 2010 | Computers & Internet
Me to!!
Dear Sir Change the power related IC but your have no idea about the IC just send me a mother board we are Repair for this Mother Board Maximum cost 11.54 $ and Normal problem in 8.65 $ charge .......ok.
Email:support@compudesk.in
Web: www.compudesk.in
Jul 14, 2009 | Computers & Internet
Bd-rom in Acer Aspire 8930G - not working
You could have a faulty DVD/CD drive.
Take it back to the shop as the laptop is under warranty.
Do not try to fix it yourself as it might void your warranty.
May 23, 2009 | Acer Computers & Internet
Sata problem
WHEN BOOTING TO LOAD WINDOWS XP START AFRESH BY FORMATING YOUR HDD FIRST AND WHEN U DONE BOOT YOUR SYSTEM UP FROM YOUR CD ROM THE DRIVERS WILL GET DETECTED AUTOMATIC AND THAN START YOUR INSTALLION.
Feb 06, 2009 | PC Chips M955G Motherboard
Asus K8S-MS boot problem..
my understanding is that if you do not have other drives in a raid configuration you do not need the raid driver loaded ,have your hard drive plugged into the first sata slot, then format the hard drive ,instal o/s and all should be good.
hope this is of help
Terry
Mar 10, 2008 | ASUS K8S-MX Motherboard
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Cd drive
First verify the CD rom is correctly installed in your computer, access "Start" - "Control Panel" after "System" then "Hardware" after "Devices Manager" in list localize CD-ROM and see your drive, if not in list, your drive is incorrectly installed or damage has occured, verify the data and power cable has plugged, if the cable is ok, try buy a new cable or change the "slave/master" in mother board.
Dec 13, 2007 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
