Acer Aspire 5315 Notebook Logo
Posted on Aug 21, 2008
Internet connection problem
Can not connect ti internet..Says modem is blocked....Can some one plz tell me how to fix this...Thank you.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
27
Points
I have same problem, saying no wireless device, thanks.
I can't log in its say internet error plz help me
You lost the connection. Go to internet access and check to see that you have a connection between the Computer and The Modem. You may have reconnect using the pass code on the modem to get it to connect to the internet.
I am trying to reconnect to the internet I put a new modem in for my internet service trying to connect my router to my ps3 and it won't let me can you please tell me what i have to do. Thank You
I see that you have replaced you modem. Have you tried connecting your pc directly to the modem? If you do not have any internet connection when connected directly to the modem, you have to call your Internet Service Provider to setup your new modem. If you can access the internet using your new modem then there is a problem with the router. You have to re-setup your router to make it work.
My router internet LED is not working plz tell me troubleshoot
Make sure your ethernet cable connecting from the router is properly connected from your modem. If it still not showing any progress, try to reset the router by pressing and holding the reset hole at the back of the router until it restarts itself; then check again.
If it still wont light up the internet led on the router, make sure your modem has connectivity; try plugging in your computer directly to the modem to verify this. If all has been done and still the router does not give you a connection, then I hope your router is still under warranty to have it repaired for free or even replaced for a new one. If its no longer, then the router might have been damaged especially if it was raining hard on your area with occassional lightnings lately.
Thank you for using FixYa.
2helpful
The tech tells me that something is blocking my firewall. I cannot connect to the internet. I have a Acer Aspire connected through Net Gear router. He wanted to charge me 130.00 to tell me how to unblock...
Try resetting the router by unplugging it from the outlet and from the modem.Also reset the modem by unplugging it for a few minutes also.After you do that it may take several attempts for it to reconnect with your laptop.
Cannot connect to wireless network
may be the modem is not able to communicate with the modem properly ... Sp plz try to reset the modem ....
Connectivity problems after Safari update.
  • check the pop-up blocked turn it off
  • check the security settings of safari
  • reset the safari to default- its safari issue
2answers
Problem to connect playstation 3 to internet
try jsut an ethernet cable and run ti from yur modem traight into it my englis bad to
1helpful
3answers
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
1helpful
  • If newly installed, try uninstalling and reinstalling the device.
  • Once installed correctly, this error is unusual and may mean the device is faulty and needs to be replaced.
  • Some modems must be installed in a very precise order as dictated by the manufacturer. Be certain to closely follow the installation instructions. Consult the manufacturer's web site for a copy of the instructions or for an updated driver.
Good luck!!!!!!!!!
Dont forget to rate this post
GRRS Setting Using Reliance Smart
cant connect to internet
extra initialization command needed
MTKBTDEVICE (chinees mobile)
[email protected]
plz help
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
