Question about Epson Stylus Color 670 InkJet Printer
Epson 670.
I have a Epson 670 or should I say about 3 the problem is that no matter what I do the 3 lights on the front flash endlessly.
Have done everything bar throw the printers out the door.
Hope there is someone out there that can help me as I like the 670 .
Thanking You
Paul
    Master:
  • 848 Answers
That usually indicates that your ink cartridges is installed incorrectly. You may want to actually remove and reinstallink cartridges, to see if that helps. If not, then I would suggest that you simply try cleaning the electrical contacts/chips carefully and gently, with Distilled Water on Q-Tips or on a lint free rag. Its possible that the electrical contacts on the ink cartridge, or inside the Print Cartridge Holder Assembly, may simply be dirty. Using damp Q-tips [not wet or dripping], gently and carefully wipe off the copper colored electrical plates on the cartridges and the electrical contacts inside the holder assy. Its best to use "Distilled Water", because it has less chemicals and minerals in it, than tap water and regular tap water can actually cause additional problems. Use new dry Q-Tips to dry off all the electrical contacts after cleaning...The only way to really eliminate a possible bad cartridge [even if it happens to be a new cartridge], is to actually replace it, or test it in another printer that uses the same cartridge and was working ok with its own cartridges installed. Unfortunatly, that is usually not practical, unless you know someone that has the same printer or uses the same cartridge in their printer...
Posted on Aug 21, 2008
    Master:
  • 521 Answers
Three lights blinking indicates that the board is faulty n all the major parts are at the end of its life.so plse dont even try to spend anything on repairs as nothing will help n u will just end up spending money for no good results.
1 more thing i will advice is it is always a better option to buy a hp printer as they can be repaired anytime for any problem and not like epson which has to scrapped after a short termed use.
  • tech expert12 Aug 21, 2008
    feel free for any queries regarding any device that u hve.its a pleasure assisting u.thanks and pls do rate the solution
  • Epson Master
  • 19,396 Answers
Try first unplugging power cord for two minutes and see if this clears the error.
  • Ginko
    Ginko Aug 21, 2008
    If basic hard reset (unplugging power cord) did not work try the following:
    1. Remove cartridges
    2. Unplug printer USB
    3. Unplug printer power cable
    4. Wait ten minutes
    5. Plug back printer
    6. Install cartridges back
    Also open printer doors and check for fragments of paper or small foreign objects. Turn printer upside down and shake gently to see if there is any foreign object inside, such as small screws etc.
    If it still returns error with lights flashing the cartridge may be faulty, if you have a different cartridge test it on the printer.
    If still no luck, well it can be a mechanic error or an electonic fault, or the ink waste full, or faulty print head.
    In this case you will need a technician to fix this, the printer is a budget model, unless it is still under guaranty the repair may not be worth.
LG 42LD560 LCD TV
mainboard failure
I suggest you change tha flash memory .
This would be the first thing to try
Jul 11, 2014 | LG Televison & Video
Tip
How to solving an Epson Printer "problem"
I thought the other day that a lot of people may be interested in having access to the vast pool of knowledge that myself and my staff dispense on a daily basis to my customers. As a nationwide supplier of printing consumables we often get asked by customers about related problems they are having with there printers, and obviously we gladly help out anyone we can as opposed to customers having to call expensive manufacturers help lines at premium rate call tariffs.
A favourite question we get asked is "I have just gone to print something off on my Epson Inkjet printer and it will not print", I then ask the customer how they have done this and have they changed any printer settings or installed new software recently. The answer is usually no I have not changed any settings or installed any thing. Our next question is "What are the lights /buttons on the front of the printer doing?" The common answer is, "they are all flashing at once, even if I switch the printer off at the socket and switch it on again".
We now know what the problem is! There is I believe a method built into an Epson printer that counts the amount of printing you have done, a bit like a car speedo measures the mileage you have done, but unlike a car where when you hit a certain mileage a light or warning will come up at worst and tell you the car needs a service. The Epson printer just stops dead and all the lights flash, if you dig a little deeper into your instruction manual/disc it tells you to call the Epson help line, who then tell you the printer needs a service at your local Epson dealers. I duly took my faithful C82 epson printer to my local Epson service centre; very help full and who charged me and gave me back a printer that worked.
This intrigued me so I asked a couple of my computer tech customers if they could shed any light on the matter, and they both confirmed my suspicions. You plug in the correct software and reset the counter. It is nothing to do with your computer, your printer, your brand of inkjet cartridges or your computer. It is simply Epson's way of getting you to their service centre.
So if you come to print with your Epson inkjet printer and it will not, and then proceeds to flash all of its lights at you. You now know what to do, unlike quite a few of my customers including my self, who spent hours reinstalling software, trying new sets of cartridges, both genuine Epson cartridge and the more popular compatible ones. I hope this saves some one some grief and frustration.
on Mar 25, 2010 | Office Equipment & Supplies
Green on light flashing red lights on 'E' light flashing other lights flashing
I'm sure you have done this correctly, but look at this Epson link
How do install my ink cartridges for the first time
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Apr 28, 2011 | Epson Office Equipment & Supplies
My Dell 670 had a blue screen when the c drive
try to remove or detach any newly hardware.and check the Ram
Feb 03, 2010 | Dell Precision Workstation 670 PC Desktop
Is Epson stylus color 670 compatible with Windows 7
Hello there...
It doesn't choose an OS. It's PC and Mac compatible.
Nov 08, 2009 | Epson Stylus Color 670 InkJet Printer
My epson 670 won't print with windows vista
hi im josh in cebu phils.friend to solve you problem in printing. you need to check the connections of your printer be sure the cables are mounted prperly on the slot.2nd check the default connections of the printer the port being selected must be the same with the port being used and laslty try to reinstall your printer software driver.thats all good luck hope i helped you.
Feb 28, 2009 | Epson Stylus Color 670 InkJet Printer
Reset waste ink counter on Epson C60 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Feb 24, 2009 | Epson Stylus C60 InkJet Printer
Epson P4000
Hit the reset button. That's what it's for. I would say I'm 99.9% sure it's not going to erase the harddrive. That's one of the good things about a hard drive unit instead of flash memory.
Nov 27, 2006 | Epson P4000 80 GB Digital Media Player
Epson Stylus Color 670 InkJet Printer Logo
174 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
