Question about Motorola Mobility RAZR V3
Address Book When I push the down arrow key to access my address book, the list will flash for a second and then goes back to the main screen. I have tried to access in other ways but it does the same thing. The result is that I cannot get to any of my phone numbers. Help!!!
    Brigadier General:
  • 7,752 Answers
The phone need to be flash , so take it to a mobile service center and have that done.
Posted on Aug 21, 2008
SOURCE:
How can i unblock a previously blocked phone number from my blackberry phone
Hello.
First, access your Block List:
  • 1 Press the "Menu" key or option from the home screen on the BlackBerry.
  • 2 Scroll to and select your "Address Book" icon.
  • 3 Click the "Menu" key when your Address Book list appears.
  • 4 Select the "Manage Numbers" option.
  • 5 Click on the "Block List" option.
  • 6 Select "OK" or "Yes" to access the block list in your address book.
Then, remove the number:
  • 1 Select the option for "Number" or "Unknown Numbers" from the block list.
  • 2 Delete the number that you want to unblock or remove.
  • 3 Press the "Menu" key when you are finished.
  • 4 Scroll to and click the "Save" selection.
Hope this helps.
May 26, 2011 | Cell Phones
Want to import email addresses into MS Outlook
Hey! follow the steps to get your job done
You can import address book contacts from other Microsoft Windows® Address Book files (.wab), as well as from Netscape Communicator, Microsoft Exchange Personal Address Book, or any text (.csv) file.
For Windows Address Book 1.
On the File menu, point to Import, and then click Address Book.
2.
Select the address book or file type you want to import, and then click Open.
For All Other Address Book Formats 1.
On the File menu, point to Import, and then click Other Address Book.
2.
Click the address book or file type you want to import, and then click Open.
If your address book is not listed, you can export it to either a text (.csv) file or a Lightweight Directory Access Protocol (LDAP) or Lightweight Directory Interchange Format (LDIF) file, and then import it using that file type.
Good luck :-)
May 27, 2010 | Microsoft Windows XP Home Edition
Contact Number
Hi, You can import phone data from a Subscriber Identity Module (SIM) card to the address book application on your BlackBerry smartphone.
Contacts in the address book can be saved to the SIM card individually. You cannot import data from the address book to the SIM card.
To import a single contact, complete the following steps:
1)On the BlackBerry smartphone Home screen, open the Address Book.
2) Display the menu and select SIM Phone Book. The SIM phone book is loaded.
3) Select the contact you want to import, then select Add to Address Book.
4) In the New Address screen, add any additional information.
Import all contacts, complete the following steps:
1) On the BlackBerry smartphone Home screen, open the Address Book.
3) Display the menu and select Copy All To Address Book.
4) Go back to the Address Book and make sure all the entries are displayed.
After adding information to ddress book you can able to veiw contact list, I hope this information will be helpfull.
Oct 14, 2009 | RIM BlackBerry Bold 9000 Smartphone
Contacts
Your SIM Card is like a floppy disk, so if you want to permanently add those people from your sim card to your Blackberry - you need to copy from the SIM into the BB Address Book. Otherwise they will be on the SIM Address Book, and you can always go look them up - but they are not saved on the BB itself.
BB: To access your cell phone address book:
  1. Scroll to select the ADDRESS BOOK icon and press [Trackwheel] to select.
  2. Press [Trackwheel] again to access the Menu screen for the address book.
  3. Scroll to select the SIM PHONE BOOK and press [Trackwheel] to select.
  4. system should say LOADING SIM PHONE BOOK.
  5. Then if you select the menu - you should have an option to COPY ALL TO ADDRESS BOOK, select YES so it will copy whats on the SIM to the BB Memory..
This will start the download process to read the contacts stored on your SIM card which were copied from your cell phone.
Mar 08, 2009 | RIM BlackBerry Bold 9000 Smartphone
Printer shows offline/Scanner has no destination list
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
Dec 18, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Address book on SIM card
You can connect it to a pc via the usb port and transfer all of it into the computer. Some programs actually allow you to see the screens of the phone on the pc so try that out.
Aug 22, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
I need to remove a # from the rejection list
go to - menu-> settings-> application settings->  call->  all calls->  auto reject-> (scroll one down) reject list->
[on the reject list uncheck number you wish to remove from the reject list. ]
-this is the most accurate answer, trust me.
Jun 18, 2008 | Samsung Cell Phones
Address book
Select the Address Book application from the main screen (with all the icons.) The address book icon is black and white in the default theme.
Press the "Menu" button (just left of the trackball)
Scroll up or down to "New Address" and push the trackball in (select the menu item.)
Fill in all the details that you have for the contact.
Press the "Menu" button again (left of the trackball)
Scroll up or down to "Save" and select it by pushing the trackball in.
Bob's your uncle!
May 28, 2008 | AT&T Blackberry Curve 8300 Smartphone
Address Book access
When you are on the phone with someone look at your screen. On the right hand side it will say options. Click the key under it and it will bring up a menu, one of the top 3 will be for Phonebook. I belive it is the very first option, but I can't remember.
Feb 27, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Address Book Failure
back up ur data, take out ur memory card  & then dial *#7370# for hard reset or contact service centre if problem persists
Oct 04, 2007 | Sony Ericsson K800i Cellular Phone
Motorola Mobility RAZR V3 Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
