Question about Dell Inspiron XPS M140 Notebook
Replace Memory Help to change the memory sticks in a Dell Laptop XP M140? I found the one on the bottom but was told the other is under the key board, how do I get to it?
    Genius:
  • 1,027 Answers
Link
click on the links on the page for removing dimm A
1. Preparing to work inside
2. Removing hinge cover
3. remove keyboard etc.
Posted on Aug 21, 2008
First turn over your laptop and remove the 2 really small phillips head srews. Then flip your computer back over and push the screen back and use a small flat head screwdriver to put in the small plastic notch where you lift the cover at the right front that holds down the keyboard, just below the screen is where you will see the small plastic panel that holds down the screen. And then you can remove the keyboard and you will see DIMM A memory slot cover. And just the reverse to put everything back together.
Posted on Aug 30, 2008
Need to reset the bios password on my dell xps m140 laptop.
You would have to reset the whole bios to default which maybe something you cannot do. The only other method would would be to take the laptop apart and remove the battery that keeps the motherboard BIOS memory powered. It should look like a large watch battery. Remove for 5 to 10 seconds, and replace. Then put the laptop back together and that should reset the BIOS, password and all.
Apr 27, 2011 | Dell Inspiron XPS M140 Notebook
Where are the memory slots on a dell xps m140 laptop?
One memory module, ('Stick') slot is located on the bottom of the laptop, in the Memory Compartment. (Has two Philips screws on the cover, and is located close to the battery release button)
The other memory module goes under the keyboard.
Here's how to replace them from Dell Support,
http://support.dell.com/support/edocs/systems/xps140M/en/sm/upgrades.htm#wp999869
Sep 02, 2009 | Dell Inspiron XPS M140 Notebook
Looking to install memory in XPS M140
Usually there is a latch at the bottom where the memory chips go. Sometimes they are situated under the keyboard...
Jul 06, 2009 | Dell Inspiron XPS M140 Notebook
Installation of memory sticks
The absolute best way to find out how and what memory you need is to go to www.crucial.com. They will automatically look at your computer online and let you know exactly the type of RAM and how many you can use..
Apr 19, 2009 | Dell Inspiron XPS M140 Notebook
2007 DELL XPS M140 LAPTOP WILL LOCK DUE TO 256M MEMORY STICK
Normally you boot up the laptop without a memory stick in the USB port.
Check your BIOS settings for the boot up device order.
You should have the hard drive as the first boot device, you can have the CD as the first boot device and the hard drive as the second boot device.
You should not have the USB port as the first boot device.
Feb 02, 2009 | Dell Inspiron XPS M140 Notebook
Install memory
Use the following steps to remove a memory or continuity module:
Turn off the computer.
Windows 98 or 2000: Click Start , Shut Down , and then Shut Down
Windows XP: Start and then Turn Off .
Unplug the AC adapter, if present, and remove the battery.
From the bottom of the computer, remove the screw holding the RAM cover, and remove the cover.
Remove the board by pulling it away from the connector at a
45-degree angle.
Align the keyed (notched) edge of the board with the keyed area in the expansion slot. Insert the board into the slot at a 45-degree angle until it is seated.
Push the front edge of the board down until the retention clips snap into place. Then replace the cover
Aug 25, 2008 | Compaq Presario Notebook
Dell latitude d60
WE NEED A ALL DRIVERS FOR DELL LATITUDE D600 MODEL LAPTOP - WINDOWS XP OS
Apr 26, 2008 | Dell Latitude D600 Notebook
Memory change
I've jus put the pictures of my laptop.. They're simple 9 steps.. you may fill the text..
Mar 12, 2008 | Dell Latitude D620 Notebook
My Dell C610 won't reconize the second stick of 256 mb memory
As the computer boots, it detects the additional memory and automatically updates the system configuration information
where did you get the memory?
If it is in properly and does't work,it is either bad or the wrong part number for your Dell C610
Nov 27, 2007 | Dell Latitude C610 Notebook
Dell Inspiron XPS M140 Notebook Logo
228 people viewed this question
Alun Cox
