Question about Hitron HRA-4100B 4 Channel 400 Watt Mosfet Car Amp Car Audio Amplifier
Application Im thinking about purchasing this amp mainly to connect with 2 10" Infinity 1052w subwoofers. Im new to car stereo setups so Im wondering if this would be a good amp for this setup (plus other stock speakers in car if need be).
    Novelist:
  • 100 Answers
I'm happy I can help a newbie. I remember when I was one and I'm happy to help you. First off, I nodiced that the fuse is only a 30 amp fuse. A quick way to see what is probably the max output of your amp is take the fuse value, in your case 30 and multiply it by the voltage you will be supplying it. Lets say you are just sitting with the car off the voltage would be 12ish volts. So your total assumed wattage is 360 watts. Which is an large amount less than the 1000watts listed. So watch out for that. Also, with subs you would want a mono-block class-d amplifier. If you need any more help at all, let me know. Good luck
-Andrew Hawkins
Posted on Aug 29, 2008
Infinity Subwoofer input signal mystery
Have you tried changing the connector leads? They can become faulty. Powered Subwoofers generally work off one connector from the amp. The Sub is a mono amp basaically. So all it needs is the main imput and an earth. One possibilty is that you have the wrong jack plug. Say a stereo instead of a mono, or the wrong size one!
Jan 26, 2013 | Audio Players & Recorders
Where to purchase vertical mounting feet & bolts for Infinity sub
Simple as it sounds, try Home Depot/Lowe's! They will have them! Been there, done that!
Mar 30, 2010 | Infinity BASSLINK Car Subwoofer
Speakers won't play ''loud at all '' Just Very faint
they dont sound loud because you need to use the DUAL voice coils and make it 2 Ohms. Google " how to bridge a dual voice coil sub"
May 25, 2009 | Infinity Reference 1052W Subwoofer - 10"...
Blown sub, butIdon't know why
if you use a right channel on one coil and a left on the other different frequencies are going in different directions in each channel thus blowing a coil or badly damaging it-z
Feb 20, 2009 | Infinity Reference 1052W Subwoofer - 10"...
2 sets of pos. and negs. on 10" infinity reference 1052w
This means you have a dual voice coil sub. It is probably a dual 4 ohm voice coil. If you hook up the left channel to one input and the right to the other you can safely push the sub but the amp will be running at a lower efficency. In other words it isn't the best amp for the job because it can't push max power to a dual voice coil speaker but it will work.
Jan 30, 2009 | Infinity 1250w Car Subwoofer
Connect Bose 901 eq to Denon avr 2807
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the Tape Monitor with any type of stereo-only sound processor (non-Bose EQ, dbx expander, etc) and the various DSP options to spread 2-channel analog source material around the room. I have a whole stack of analog processors, tape and CD recorders slaved to my single Tape Monitor and then into a dbx400x Program Route Selector. It not only expands my Tape Monitor to handle nearly unlimited external devices but it makes routing for listening or recording easy with simple pushbuttons. But I digress...
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs (probably like yours) so I can drive up to 6 external amplifiers if I want to (I drive 4).
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front L&R Pre Out >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> NEW amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Oct 19, 2008 | Bose 901 VI Main / Stereo Speaker
PS-12 subwoofer problem - Infinity Customer Support number?
Fixed the problem...I just purchased another one online (from a store that has a good return problem) and will return the one that doesn't work! Cheers! :)
Jun 26, 2008 | Infinity PS-10 Subwoofer
Infinity Basslink killing battery
Both issues sound like they are related to a non-connected or loosely connected remote wire on the Basslink.
If you're using RCA preamp wires to connect your stereo to the Basslink, make sure the remote wire input on the Basslink is solidly connected to the stereo's remote output.
If you're using the speaker level inputs on the Basslink and not the RCA preamps, make sure the remote input is not connected, as the Basslink will automatically turn on when it senses the speaker level inputs are active.
Mar 19, 2008 | Infinity BASSLINK Car Subwoofer
Car stereo crossovers
you should be able to remove the passive in-line crossover, but since it is blocking everything below 3500 hz, there is no need. leaving the passive crossover in place will also help protect the tweeters if something fails in your setup as any amped frequency below 3500 can seriously damage them.
Nov 11, 2007 | Infinity Kappa 10.7t 1'' M.M.D. Dome...
Car Audio & Video Logo
82 people viewed this question
Top Hitron Car Audio & Video Experts
xxxxxx xxx
Are you a Hitron Car Audio and Video Expert? Answer questions, earn points and help others
