Question about Brother MFC-5440CN All-In-One InkJet Printer
Brother MFC-5440 Print Head
Colors are printing fine, no black, even with a new cartridge. I've run the cleaning cycle more than 30 times. I can 'capture' the print head by unplugging the printer while it is trying to print, but how do I remove the print head to clean it? Also, what is the best cleaning solvent? Water, isopropyl alcohol, or ...?
  • BurgerKIng Sep 08, 2008
    UNable to Print Error Message on LCD Display
  • Anonymous Mar 14, 2014
    mfc-j265w black print head will not clean. Have tried several times (30), but still will not print a good quality test.
  • 74 Answers
To remove it you pretty much have to take apart the printer, tip up the lid and try and get the scanner cover verticle and then slide to the left it should detach and then undo all the screws you see on the top were the pinter head is, and i would recommend Alcohol Swabs (IsoPropyl Alcohol), Then just reverse the dissassimbay directions
Thanks Mitch
P.S. Don't forget to rate me
P.S.S. If you follow my directions you do so at your own risk, I am not liable for any damages that occur
Posted on Aug 22, 2008
When I print the Black ink does not print on page at all. All of the colors cyan, magenta and yellow are fine. I haver replaced the Black Cartrige and Run the printers cleaning cycle several times.
maybe you run out of ink for black, try to use other ink, if its still the same then their a stockup ink on your head of the printer and better to replace it. I think once you purchase an ink cartridge of cannon their is also printer head included. Hope it helps thanks.
Sep 19, 2011 | Brother MFC 490cw Color Inkjet...
I have changed all cartridges. Colours work fine, but cannot print black. Help, please!
try to clean the prinhead 2-3 times,if the problem persist you need to change the print head
Feb 24, 2011 | Brother MFC-5440 Printer
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
My black ink printing all of a sudden stopped..ink in cart.all other colors work fine
All brother machine have a one year in parts and labor this machine have a print head problem.
Oct 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
MFC-790CW; will not print the black color..
You probably have a plugged print head or the black ink feed is plugged.
Depending on how bad it is you may find it easier or even cheaper to replace the printer.
If this is a ink caused problem you stand a chance of fixing it if you are patient but you might go through half an ink cartridge to get it working, If it is stubborn it can take 20 or 30 cleaning cycles before you see any black. You can try using household vinegar (dissolves the dried ink) on a qtip or lint free paper towel to try to clean the print head. To do this you remove the ink cartridge and very gently rub the towel with the vinegar on the print head. This might require you to move the print head to one side so you can see the actual print area (where the ink comes out). Keep doing this until the towel starts to come clean ie not as much ink coming off. Then run a few print cycles and if this works your printer will print as good as the first day you had it.
The next stage would require filling a old clean ink cartridge with vinegar and running cleaning cycles. Usually can be pretty messy and you should rethink buying a new printer but will really clean things out.
It is also possible that the print head has picked up clay or paper lint from the paper and this has hardened like a cement. That means replacement.
Aug 17, 2009 | Brother Multi-Function Center MFC-240C...
Print head for brother mfc420cn
Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print
head. You can start the cleaning process manually if needed.
Clean the print head and ink cartridges if you get a horizontal line in
the text or graphics on your printed pages. You can clean Black only
or three colors at a time (Cyan/Yellow/Magenta), or all four colors at
once.
Cleaning the print head consumes ink. Cleaning too often uses ink
unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause
permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press ▲ or ▼ to select Cleaning.
Press Menu/Set.
3 Press ▲ or ▼ to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service
Hope that helps,
Take Care,
Michael
Nov 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Black Ink Cartridge
I don't the meaning of the word "clogged" but the better way to clean a printhead is to put hot water on a soft clothe and gently put the cartridge on and off a couple of time. You will see if the cartridge let ink leaking. Important do not scrap with your clothe under the cartridge.
Mar 08, 2008 | Brother MFC-3240C All-In-One InkJet...
Balck ink not working
brother mfc-5440 ~ same exact issue on not printing the black AFTER purchase new cartridge (again!) ~ i should have checked here first.... NO MORE BROTHER printers in our future & will tell all our friends, too....
Mar 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Not printing black
First of all the print head is clogged just because you have tried to print repeatedly while some of the cartridges are empty. This results ink burn in the nozzle and clog. My recipe: Heat some drinking water in the kettle (70-80 C). Put the head in it and shake gently several times until ink is completely clean (10 minutes). Change the water do the same again. Change the water again (70-80 C) this time put a spoon full of apple vinegar (becomes a natural acidic solution very dilute) shake again, clean with cotton stick. I did it and started to love my mp800 again as much as I just bought it, all colours come back and started to print superior photos again...... Do not touch heads' copper poles and cartridges poles because of the static electric they may mulfunction and colours may becaome totally mixed for a short while...
Aug 22, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
655 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
