Question about SanDisk Sansa e260 MP3 Player
16 MB,load fail image file - SanDisk Sansa e260 MP3 Player
    Scholar:
  • 155 Answers
Update the firmware of your device. You can download the firmware at forums.sandisk.com site check if your device is a version 1 or a version 2 player first. But normally this problem occures on version 1 player.
Posted on Aug 22, 2008
Does the Bell & Howell DV65 take an external memory card, if so what kind?
Storage Memory Type: Built-in · CompactFlash Card Type I · SmartMedia Card Built-in Memory Size: 16 MB File Size (High Res.): 0.8 MB (160 images on 128MB card) File Size (Low Res.): 0.16 MB (about 800 images on 128MB card)
128 MB memory card
Jul 23, 2010 | Bell & Howell DV65 Digital Camera
Cant get passed recovery mode
this came from another post on fix ya.
For me the solution was this:
After entering the recovery mode (turn off the player, move the hold button to the right, and press the on and rec button, then connecting to the computer).
when the 16 mb folder opens create a NEW FOLDER (not a text document) called "Sansa.fmt". then disconec the usb and it was fixed.
Jun 02, 2009 | SanDisk Sansa e260 MP3 Player
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
Hi I have an LG DVD±RW, it used to work properly but few days ago i tried to burn an iso. image it didn't work Device: [1:0:0] HL-DT-ST-DVD-RAM GSA-H55N 1.02(E:) (ATA) Firmware Version: 1.02...
According to the log file, there was a spindle servo failure. The spindle servo is responsible for maintaining rotational speed accuracy. I'd say your drive is pretty much dead. See if you can read a disk in the drive. I wouldn't be surprised if it had a tough time just reading files.
Jan 23, 2009 | NEC ND-3500A DVD±RW Dual Layer Burner
Unable to recover my sansa
i guess you will have to reinstall the hole mp4
Jan 18, 2008 | SanDisk Sansa e250 MP3 Player
Guitar Hero III on PS2 Saving Failed
Could be. Maybe the game doesn't recognize the 16 MB. You can try an original 8 MB Sony one. They're not that expensive anymore. But first try the other Memory Card slot.
Let me know if it worked. Please rate.
Greetings,
DarkNeogen.
Jan 05, 2008 | Sony PlayStation® 2 Console
Sansa 250R ~ It will not reformat
how can i refresh the data base, tks
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
Load main image failed switch to recovery mode is on my screen and it is black I cant get it to do anything how do you reset it or switch to recovery mode?
(( Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. )) When i get to step two, and did what it told me, i get this ( Application failed to read the version details ) What should i do?!?!?!?!
Aug 05, 2007 | SanDisk Sansa e260 MP3 Player
HELP ME PLEASE!!!
Hi Alina. Seems like oyur Sansa E260 is experiencing some system errors. Here's a procedure you could try -- it's setting your player to the Recovery Mode and re-flashing its firmware. I hope this helps: RECOVERY MODE Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the "Load Main Image Failed" notification in the first place. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try steps 1-4 again
Mar 24, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
