Question about Medion Computers & Internet
19 " laptop monitor drivers
Where can I get the latest drivers for my new 19' Medion Notebook Monitor. The display is poor I have a GE Force M600M display driver.
    Scholar:
  • 133 Answers
On Notebook monitors it is reccomended that you set the monitor at the optimal resolution that is reccomended by the manufacturer (usually the highest) Based on my experience , it is normal for a laptop to display fonts kind of iffy at lower resolutions. This is because image stretching is taking place and things are out of proportion.
Posted on Aug 21, 2008
  • Jason Carver
    Jason Carver Aug 21, 2008
    One more thing I forgot to add, your notebook manufacturers website is the best place to get drivers from, the Nvidia site is not too good with posting mobile graphics drivers since they are always custom from the OEM.
Monitor wont connect to medion computer
u could try using a VGA connection or HDMI connector to connect asuming its windows switch off youre LCD monitor on the key board of youre laptop try downloading drivers for youre monitor to make windows aware of new hard ware thanks
Apr 05, 2014 | Medion Computers & Internet
Will my Envision 19" monitor,
You will need to set the display resolution and vertical sweep rate on the computer to something the monitor can handle. The monitor works best at 1440 x 900 at 59.8 Hz vertical rate. If your laptop's graphics chip doesn't have this setting (available settings are listed in the Display control panel), then look on page 19 of the monitor's owner's manual to find something that matches a resolution listed in the control panel.
Sep 21, 2011 | Envision Computers & Internet
Notebook can play a Dvd but the pictures are not displayed
try to connect rhe notebook to a external monitor and cehck if you can see the movie
then disconnect the external monitor and the image should return to the notebook screen
also you you should check in the screen monitor properties in the control panel that onlay has enbaled the notebook monitor
Mar 29, 2011 | Medion md40298 Notebook
Hooked Samsung SyncMaster 931BF monitor to laptop and the letters on the screen are choppy. I can play with the settings on the monitor but can't get the letters to line up straight.
This looks like a driver/resolution problem. Which laptop are you using? New laptops shouldn't give you any hassles, but older models don't always have the graphics cards to support all monitor sizes.
Make sure your monitor driver is installed on the laptop and that you have the latest graphics drivers installed for your laptop.
You can download the screen driver here: http://driverzone.com/device.php?id=55741
Then check that the resolution for your monitor is set correctly on your laptop under display properties. The native resolution for the screen is 1280x1024.
Hope this helps,
-LL
Feb 23, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
My external monitor suddenly has a blue tint
Try a different monitor, if it is OK then your 19" monitor is faulty or the video cable is faulty.
Apr 06, 2009 | HP Compaq Presario F730US Notebook
Laptop dispalys to monitor but laptop panel cannot be activate
Thanks for all the details..
The issue seems to be with the video card drivers here...
Go to www.hp.com/suport and download the latest video card and the chipset drivers
before you download ...uninstall the nvidia chipset or any display software from program and features.
after you have installed the software.. go to the nvidia control panel > setup multiple monitors. and browse throughout the options >
It should be dual display and not extended display.
Also try with a new user profile...
Hope this helps..
Regards,
Anup
Apr 05, 2009 | HP Compaq Evo n610c Notebook
Can't drive monitor
Try moving the monitor down to a lower res. I would try 640 x 480 first and then go up from there. Also, some adustments may be required in displays for the second monitor....
Mar 07, 2009 | Acer Aspire 2930-4661 Notebook
MONITOR MEDION MD7317 NOT WORKING
i have some 19 inch medion monitors that have the same problem .. they make a lot of noise and the screen might be jittery/fuzzy ... i found the following:
several capacitors in the power supply (inside the monitor) had their tops buldging .. that shows that internal pressure was high in the caps, usually caused by them being hot and thats caused by high internal leakage .. the caps may eventually blow out the tops (explosion vents) .. the caps are designed to do that instead of becoming a bomb ..
all the bad electrolytic capacitors i have seen so far on these monitors, motherboards and other electronics have been chinese made .. they made millions of bad caps over several years ..
almost all the bad caps had buldged tops but not always .. once in a while i see one thats open but not bulbged .. probably venting elsware ..
i changed the obviously bad caps and the monitors returned to like new performance ..
i dont know about the 17 inch but the 19 inch medion flat pro display is not too hard to take apart .. about 30 screws or so ... speakers have to be unscrewed and you have to be careful not to stress cables that go to the push buttons .. of course you have to know how to solder without bridging paths
Feb 02, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Computers & Internet Logo
55 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
