Question about GE Kitchen Ranges
GE profile gas range. The spark ignitors are activating on their own. One spark in particular is popping around two pops per second. It occasionally switches to other burners, but is mostly on one. No gas is on; the knob is turned completely off; it even pops when you turn the burner on. It just started doing this a few minutes ago.
  • 770 Answers
Check to see if the knobs are pushed in the best thing to do is remove all the knobs there is a swich behind them that turns on the spark mod
Posted on Aug 21, 2008
GE Profile Spectra XL44 oven- Makes a popping noise while heating up
assuming you have a gas rang here sounds like a bad ignitor, too long to light causes a "popping "noise when it finally does, as well as extending cooking time and perhaps slight smell of gas while cooking, all signs of bad ignitor.when you start the oven should light bake bar in 40-60 secs. any longer, bad ignitor
easy part to replace yourself part num wb2x9154, remove bottom of oven cavity, 2 screws mount ignitor to burner and 2 wires lead from ignitor( use wire nuts provided if needed . and makes no difference which wire goes where theres no polarity.
Feb 26, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
How to test ignitor if it's working properly part#wb2x9154 - GE ignitor
You can use an ohmmeter or just swap the wires on the spark box. Hint: they all spark no matter which burner is turned on.
Eric
Apr 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Range, oven doesn't heat up on any
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
Jan 28, 2010 | GE Profile JGS968 Gas Kitchen Range
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove ignator makes
sounds like you got the electronic ignitor valves wet try blowing them out with air or don't use for a few hours
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
May 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Cooktop
Do you hear the spark ignitor trying got light the burner?
If not, then make sure there is not a residue or film of cleaning solution on the burner bases or burners themselves. It could be coincidental that the spark ignitor failed when she just happened to be cleaning the unit.
Jan 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Large burner only sparks for other values to light and won't light by its own switch
sounds correct, if it didnt spark at all and you had not replaced the igniter I would check that the wire from that igniter be followed to the other end to verify that it had not come unplugged at the other end.
On a new range I bought that igniter would not spark even though the others did and its wire was unplugged
Oct 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
178 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
